Question about Joy Toshiba M105 S3002 Notebook
2 yr old spayed approx 60ml of windex over the
2 yr old spayed approx 60ml of windex over the keyboard, the screen has like a water mark in the bottom left cnr area. will this correct itself ?
    Guru:
  • 830 Answers
The windex may have seeped up into the screen. It should dry in a few weeks.
Posted on Oct 03, 2009
Fix wet tv
Replace all ur vertical section condenser .
Apr 15, 2014 | Televison & Video
No color when playing dvd
try to connect cables again. make sure you push them strongly to maka sure it works. if that won't work your dvd or tv is damaged
Apr 06, 2010 | RCA Televison & Video
I have a trouble code 11 on my Rinnai model 2532 water heater which indicates no ignition. I checked for gas supply by turning the furnace on which is approx. 1 ft. away, it works. The water heater is...
11 is a ignition failure code. Could be alot of things, I suggest calling a tech who has repaired these before. Pull the front cover off and have a helper turn on a hot water faucet. Look thru the viewing window to see if the unit is firing then going out. If not, clean out the water filter on the inlet side of the plumbing. You will need to turn off the water supply prior to cleaning it. If the unit fires but shuts off seconds after ignition, you may have a dirty or bad sensor. Call a proffessional at this point. Sorry
Oct 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Screen seems to have scrape on-how expensive is new screen-only 4
Hi, dealer cost on the screen assy. is $290 plus s&h which is probably about $45, been quite awhile since I ordered one so not sure on s&h. You may be able to seperate the 2 screens and clean it up depending on what caused the mark, be advised you clean these with warm water and a LITTLE dish detergent . NEVER use windex or any other chemical type cleaner. rub gently straight down on front screen and in a circular motion on the inside screen. Before seperating the 2 screens mark both of them with a piece of tape at the top edge so they go back together exactly as you took them apart or the image will be all blurred, hope this helps, video-tek
Feb 05, 2009 | Hitachi 57F500 57" Rear Projection...
I need to know how to clean the LG flatron L1953T screen without damaging it in any way? should we just used windex or not? it has been wiped with a damp cloth and now has water marks.
Please do not use Windex. Use Anti-Static Monitor Wipes for LCD screens. Using Windex or other cleaning solutions like it will cause streaks on your screen. Damp cloths have the same effect as Windex.
May 04, 2008 | Computers & Internet
Liquid leaked into tv
Hi Tracy,
I have the sweetest grandchildren and tey are always willing to help also, so we have to love the children for all their wonderful help. ( NOT !!! ...lol ) But lets not send your son to the adoption web sight just yet. I'll start by letting you know ( in a sigh of releif for you ) that your tv is not damaged forever, although, when the windex drys, you will probably see a dirt stain on the screen, since the windex probably did it's job and cleaned the dirt off, unfortunatly the residue is between the screens. You have 2 layer of plastic screens for your TV. One is a lexan shield and the other is a riffled substance plastic. To seperate the two of them, you need to take the front of the TV off, normally by removing screws from the inside of the TV ( this can be a tricky job and I really suggest you have a pro do it if you haven't worked on TV's in the past ). If you do it, be extra careful not to break the screen or sheild after removing as they can get a bit pricey. When you take them out, they will seperate ( one lays on top of the other, no real trick to them ) and then just grab your windex ( the remains of the bottle that your son left you ) and clean them like you would glass. Of course after you clean the screens, replace them in the oppisite proceedure of taking them apart and wella, all is ok again and junior remians a loving and helpful son. smiling. I hope this helped. Nice day.
Ed
NC Electronic
Mills, Wyoming
Nov 17, 2007 | Sony KP-46WT500 46" Rear Projection...
Water damage
take the front screen off inspect it, wipe down the tubes and mirror with paper towels and a glass cleaner dont overspray. try that. good luck
Aug 15, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Joy Toshiba M105 S3002 Notebook Logo
112 people viewed this question
Top Joy Computers & Internet Experts
john h
Andrew Taylor
Andrew Taylor
Marlin
Are you a Joy Computer and Internet Expert? Answer questions, earn points and help others
