Question about Toshiba TDP-MT200 Multimedia Projector
Yes an body there
Yes big probleme
  • 2,236 Answers
Please explain. need more info.
Posted on Nov 11, 2009
Do you have to replace the throttle body when you replace the tps
Hi OC, I'm glad to help!
OC, the best way I know to help you with this problem is to tell you to call the dearlership and if they offer the TPS without the Throttle Body, then yes you can replace the TPS only. NOTE: If they only sell the Throttle Body and don't offer the TPS by itself then you'll need the entire Throttle Body. If your asking if its OK just to replace the TPS the answer is YES, unless you have a problem with the Throttle Body itself like a vacuum leak or something like that. Hope this helps and have an awesome day OC.
Mar 07, 2014 | 2011 Chevrolet Malibu
Enging just sputtered then quit
If you have throttle body injection (TBI), look at the spray pattern of the injector spray when someone cranks the engine over. You should see a fine mist cone pattern of the injector spray (downward) into the throttle body. If the cone pattern looks good, check for spark-maybe the ignition system has developed a fault. Post back if you need more help. What year and what size engine, 4 cylinder 2.5L, or a V-6?
Jan 25, 2014 | Pontiac 6000 Cars & Trucks
My old toshiba t.v. has short bodys and big headed people in the screen do i need to replace a tub ?
Yes you must replace the tub, with that brand tho the more expensive the tub, the more efficient it will make your Toshiba viewing experience.
Jul 21, 2012 | Computers & Internet
I HAVE BIG PROBLEM WITH DOORS OF MY 1007. AS FIRST, THE DOOR ARE TOUCHING WITH REAR EDGE, CAR BODY BECAUSE THE DISTANCE BETWEEN DOOR AND "CAR BODY" IS ONLY 0,5 mm. IN NOONE SERVICE IN CROATIA ...
sorry have no experiance of this problem but how about a few days away and drive into italy or greece whatever is nearer ,and find a peugeot dealer
Sep 12, 2010 | Peugeot Liberte Cars & Trucks
I have problems finding parts for the 1999 Chevy K1500. Most parts I find are for the 1999 Silverado model. Is there a huge difference in the 2 models?
Yes big differance. That is the year changed for the body style. They will be getting you parts that won't fit your truck. Tell them it's for a 1998 and go from there. Good luck
Dec 21, 2009 | 1999 Chevrolet K1500
2001 Galant won't stay on.
Looks like gum and carbon deposits have clogged some critical parts in the engine, such as injectors.
You would need to get to the 'throttle-body'.
1. Trace the big intake-air hose to where it ends on top of the engine. This is the throttle -body.
2. Loosen the clamp that's holding the big-intake air hose. Pull off the intake air hose from the throttle-body.
3. Spray some "Throttle Body & Carburettor cleaner into the throttle-body. You could use the entire can.
4. Wipe off excess gas from the throttle-body with a piece of rag.
5. Reconnect the intake air hose, and check if the
problem has disappeared.
Dec 16, 2009 | 2001 Mitsubishi Galant
99 E250 ENGINE INTO 99 EXPEDITIOIN
YES THERE IS GOING TO BE A BIG DIFFERANCE IN THE ENGINE SET UP IF THESE ARE TWO DIFFERANT YEARS YOU MAY RUN INTO A COMPUTER PROBLEM ALSO. CHECK THE YEAR OF BOTH ENGINES IF THEY ARE 3 YEARS OR MORE APART I WOULD BE USE CAUTION.
Sep 15, 2009 | 1999 Ford Expedition
Self Start problem...
Hi and welcome to FixYa,
Your description is the starter relay making the clicking sound. Problem could be any of 2 possibilities:
  • starter relay/solenoid; and/or
  • starter motor.
To determine which, jump the 2 big terminals of the starter relay/solenoid when starting the bike; if the motor turns, the relay/solenoid is defective; if the starter motor does not turn, the starter motor is defective (most likely the carbon brushes).
Of course other possibilities still exist, such as:
  • loose, corroded battery terminals, relay, starter terminal/connectors;
  • weak battery.
  • open, corroded fuse/fuse terminals.
Good luck and Thank you for using FixYa.
Jan 17, 2009 | 2006 Hero Honda Karizma
Front brake calipers hanging up
i'll do more research on this tomorrow.
yes there is a valve body
yes it could be the master cylinder
and as odd as it seem both calipers could have failed at the same time. incidentally another issue would be that the brakes locked on. i presume he changed the pads AND the rotor(s).
as i said i'll do more research in the morning on it. i have to change both front rotors and pads on my van on wednesday... might even notice something then that may help you.
You didn't mention if this vehicle has abs brakes... if you have stop you will know whether you have them or not.
actually something else that has occured to me... when you apply the brakes is there any shaking or do you feel a pulsing in the brake pedal ?
Robert
Sep 09, 2008 | 2000 Jeep Cherokee
Toshiba TDP-MT200 Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
