Question about QSC MX1500A 2-Channel Amplifier
I have a cs 800s same problem!!!!
I have the same problem , only one channel works, but buth power lights for the chanels are on, what could this be ???
    Champion:
  • 243 Answers
Change the back switch named Stereo/Bridge to Stereo Position, then re-check again.
Posted on Nov 08, 2013
Power comes on, screen "works" but not possible to tune in a channel. yes Chanel/program listing but will not go to a channel. how can I tune in a channel
You probably have to do a channel search as part of initial set up (or later) to find available channels in your area.
Oct 23, 2016 | Televison & Video
Video will not display on chanel one screen dark but red record button showing on
If you're connecting to the TV with a unit that you believe is supposed to be transmitting on channel one, check other channels and also check for a switch to select what channel it's transmitting on
Feb 02, 2015 | Televison & Video
No Power to A channel
check output transistors also the driver transistors.
Jul 28, 2013 | Peavey CS® 2000 Amplifier
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Shashij_2001@yahoo.com
TURN THE BALANCE CONTROL IN THE MIDLE
Jul 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
PEAVEY CS 800S WHERE IS THE FUSE LOCATED? WHAT DOES IT LOOK LIKE?
There are many variants of this amp depending upon its age. The fuse will be a ceramic one that should be solid white and be around 10A or more. This will be about 1-1/4" long and located inside the amp. Remove the top cover for access. It will be in a fuse holder. Please make sure that the unit is unplugged before opening.
Dan
Jul 05, 2009 | Sony STR-DE595 5-Channel Amplifier
Cant get my cable hooked up
check your unit if it is cable tv compatible.then, hook your cable to antenna in.then do the manual tunig/search for channel.if not,you'll need to buy a cable converter ,much better if it has audio/video out.
Mar 29, 2009 | Mitsubishi CS-40503 TV
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Power problems
Hi Gohan102,
Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
102 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
