This is a new part for Dayton and of course the manual is not to be found...the brief description is well, brief. My problem is that Parts Express outlines it as wall mountable with 16" studs and I have 13.5" on center studs for my application. Will I still be able to utilize this product?
Only you have the answer. Is there enough adjustment if you mounted on your wall specs? If not absolutely no!!!!! To support the weight, you must be in the stud.
But a question. Is this an interior or exterior wall. If you house is made of concrete block, the exterior wall only has 1x2 studs. The interior studs are usually framed by 2x4 (1.5x 3.5 in reality). Some houses use aluminum studes which I personally would not use.
If you are on an exterior wall, you couldn't use wood screws anyway. I would suggest using the appropriate TapCon. A screw made for concrete. An appropriate lenght might be 2 1/2 to 3 inches. This depends on sheetrock (1/2 or 3/4 inch) the depth of the bracket (you need to measure). To find the sheetrock depth simply take the cover off an AC receptacle. See if you some how measure the entire distance to the actual outside wall (stick a skewer along side the box till you make contact). Add 1 1/2" for the concrete, whatever your bracket depth is (at the point were screws go) and viola, you have the proper length of the screw. To size the screw, use the larget that your bracket can take (usually a #10 or 12). Definately pre-drill using the right size bit.
I need to buy a replacement woofer for my home stereo speakers - It is a 15" woofer for a...
(More)
I need to buy a replacement woofer for my home stereo speakers - It is a 15" woofer for a Cerwin Vega floor speaker about 15 years old.
Orderd a Mackie swa 1801 7 months ago the dealer says mackie is slow in producing &...
(More)
Orderd a Mackie swa 1801 7 months ago the dealer says mackie is slow in producing & shipping. Now after seeing all the complaints about the Mackie should i look for another brand, any suggestions
My son has just returned a pair of tannoy 605 speakers that have been unused for 10 months and now...
(More)
My son has just returned a pair of tannoy 605 speakers that have been unused for 10 months and now there is no ouput when plugged into amplifier.
