Question about Dryers
The timer is running but the dryer will not come
There is power to the dryer and you can hear the timer running but the dryer will not come on when you shut the door and hit the start button
  • 986 Answers
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Posted on Oct 03, 2009
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
My dryer will run for a while but then it stops. I can still hear the timer ticking and if I push the button again the dryer will run again.
My Best Guess would be a bad power connection, or just a bad connection, A bad timer or Bad Motor
I would ckeck the power cord connections first and even the outlet. Making sure all the wiring is sucure.
Of course make sure you turn off the breaker to the outlet befor serviceing and unplug the machine befor serviceing
Sep 05, 2010 | Amana DLE330RAW Electric Dryer
Went to push the dial in to start and it won't
first make sure you have power to the dryer.if you have power to the dryer than put your ear to the timer and see if you hear the timer running.if the timer is running than you nead to unplug the dryer and pull the dryer away from the wall so you can remove the vent hose and the back panal and the power cord cover.next look down and to the left and you will see a white plastic thermal fuse.remove the wires from the fuse and use a meter to see if the fuse is closed.if it is not replace the fuse and replace the back and power cord cover.plug the dryer in and check unit out.
Jan 10, 2010 | Whirlpool LER4634J Electric Dryer
My Maytag DE4000 timer will not move once the dryer is started. The dryer will run until manually turned off.
there is a clock motor in the timer ether its not geting power or has a striped gear if you can hear it runing then its the gear
Oct 20, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Timer motor keeps running on dryer
sometimes as a timer gets older the timer motor will get a little loud. timer motors run even when the door is open. if the timer advances to off and everything works fine you don't need to worry about it.
Nov 19, 2008 | Dryers
Dryers Logo
48 people viewed this question
Top Dryers Experts
