Question about Goodman Heating & Cooling
How is not cooling down, it is warming up. The compressor is spinning
  • 358 Answers
If the compressor works and both fans (inside unit and outside unit) work ,probably the a/c unit is low on freon , or the inside unitcoil is dirty.
Posted on Oct 03, 2009
I have an Amana heater/airconditioner (Prestige I think) that is not cooling. The outside compressor fan was not spinning, so i I changed the capacitor on the unit. It now spins, yet vent air not cold
If that fan stopped your compressor overheated, shut off on thermal overload. Carefully cool compressor with water hose and restart. If the big copper is cold ,small copper warm, compressor is running. Check capacitor on compressor
Jun 06, 2016 | Amana Heating & Cooling
Freezer not cooling
The clicking you are hearing is probably the compressor trying to run but shuts down after the minute. If your refrigerator has a fan cooling the compressor make sure if is running and the coils are not blocked with lint. A warm compressor is a good sign a hot one is not. The compressor start device or relay could be causing the problem.
Apr 01, 2014 | Refrigerators
COMPRESSOR WARM TO TOUCH ,OVERLOAD RELAY CLICK WHEN PLUGGING INTO THE OUTLET
Compressor faulty, most probavly. let it cool altogether and try to restart. If it has a start capacitor, replace that first in case it is that simple. If the relay and capacitor are ok it is time to replace the compressor.
May 16, 2012 | Refrigerators
On a 2001 chevy silverado 2500HD the ac blows cool in idle or slow speeds but while driving the air gets warm and then cool warm and then cool etc. i cant tell if the compressor is cutting on and off
You might be low on freon if not compressor going bad to see if your compressor is going on and off turn on a/c on max have some one hold gas peddle down around 1500 rpm or just at a small fast idleif compressor goes on and off recharge it most likely one or two cans will be enough
Aug 24, 2011 | 1999 Chevrolet Silverado 1500
GE Monogram refrigerator does not cool. The fan on top was loose and not spinning. I fixed that, and it now spins properly, but he freezer and frig will not cool at all.
I need you to pull away from wall and remove cover over compressor and feel compressor for heat. If too hot to hold hand there or if warm or just cool. Tell me what you find. I would like to help you solve this if you like. Sea Breeze
Feb 21, 2010 | GE Monogram ZISS480NRSS 48" Built-In...
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
Fridge is not cold
Side by side cooling units usually have 2 compressors, one for the freezer and one for the refrigerator. The refrigerator compressor may be bad, or not pulling enough power, or there may have been a leak in the tubing that the compressor uses to cool the unit with. To diagnose the problem, be aware of the noises the unit makes, and check to make sure it is a 2 compressor unit. If you only hear one compressor running then your compressor is bad, if you hear one running too often, then your tubing is bad, if the back of the refrigerator side is warm but the inside is not cooling down, then the compressor is not drawing enough power. Keep in mind that the radiant heat from the operational (presumably) freezer side may cause the refrigerator side to appear warm. (usually there is a type of wire backing with tubes running along it, these tubes should be mildly warm.)
Jun 15, 2009 | Samsung RM255LASH Side by Side...
Cooling Fan is not working automatically
thass as good idea, but instead justreplacethe existing fan ( which is your problem)the fan is no good, so rewiring will not help any. replace the part!
Mar 18, 2009 | Whirlpool ED5VHGXM Side by Side...
Kenmore side by side fridge
It sounds like your compressor is having trouble starting, and over heating. this could be one of the following
  1. start relay is bad
  2. run capacitor is bad
  3. compressor run/start winding burned out
Try unplugging the unit for a few hours to let the compressor cool down. Then plug it back in and see if the compressor starts. If it starts after it has cooled down, then it is likely out or low on refrigerant. If its low or out of refrigerant it will run until it over heats, then kick out on thermal overload. This is because there is not enough cold refrigerant being pulled back into the compressor to keep it cool.
Jan 28, 2008 | Refrigerators
Heating & Cooling Logo
19 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
