Connections of cables
Can not connect power led, H.D.D, rest and pwer sw onto the mother board
    Problem Solver:
  • 7 Answers
There should be a set of pins on the motherboard that connect all those cables to, if they are not labeled then you are going to need the motherboard manual. You can probable get that from the manufactures website.
Posted on Dec 21, 2007
  • 59 Answers
If you are unable to to find out what cable goes where look on the motherboard and sometimes its printed in small setters and abbreviated. Usually if you have hooked up these connectors before on other computers they are usually arranged the same for almost every model and brand of motherboard and chassis so i recommend just guess doing trial and error.
Again If you are unable to find any labels, just play around and do it by trial and error, this will not damage any of your hardware since this will not cause and overvoltage or short circuit, all these cable connections are only for switches and LED's which hardly use and current or voltage so electrically doing this by trial and error is safe trust me.
I only recommend this if you are unable to find a documentation from manufacturers for the motherboard.
Help needed to connect power cables to Abit AV-8 mother board
Bottom right you will see a set of pins  - 2 rows on a black base, color coded: these are the system pins. Next to them you will find printed on the board the description of the connections to them - follow it.
Jun 22, 2010 | Abit AV8-3rd Eye Motherboard
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Nov 25, 2009 | E-Machines eMachines Desktop PC
How to connect power led ,HDD,Reset,power SW cables in ESYS 865gv/775 Mother board. Thank you
Here is the link to read and find out where you connect power led & etc.:
A tip where you can recognize also in your motherboard.
Rhis is where you will hook in the connections from your case. These are mostly the different lights on your case, such as power on, hard drive activity etc.
Open this browser:
www.yboyandrei.com/865GV
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 25, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Need to know where LED wires connect on Foxconn mother board.
You can try going to the following site and download the user manual for the motherboard , which would give you the detailed diagram of which cables to connect where
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000001
Thanks
proton
Apr 08, 2009 | Foxconn 661FX4MR-ES Motherboard
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Front panel power supply
You need to find out what mother board you have and look up the connections for the led's as most boards are different. Let me know if you need any help.
Dec 22, 2008 | E-Machines (T2958) PC Desktop
Pwer led,resetsw,hdd led,pwer sw
It appears your board is made by Jetway.
Heres your link for the manual:-
http://www.jetway.com.tw/jw/downloadshow.asp?productid=V266B#
You can also download drivers et,c. from the same site.
Please don,t forget to rate the Post.
Best wishes mike @Compurepair
Mar 29, 2008 | Intel Motherboard
Mother Board connection
Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4p800/e1324_p4p800.pdf
Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
Good luck & please vote....
Dec 22, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
105 people viewed this question
Alun Cox
David Payne
David Payne
