Question about Makita Saws
The spring for the blade cover has come off how do you fix it? my dad has given me his saw to fix the spring that brings the blade safety cover around, how do you fix it the the mounting post. When I do this the spring rubs on the guard.
  • 2,176 Answers
If it a Makita saw it will rub on the guard slightly, What is the model number or you can go to Makitatools.com and type in your model number to see a breakdown for this tool. The post is on the back side of the upper guard and there is a hole in the guard itself for the other end.
Posted on Oct 03, 2009
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
When replacing blade spring for the safety cover fell out. Not surewhere it came from.
On most brands of circ saws, there will be a lug/tab on the back of the lower blade guard and also a hole or screw point on the upper inside of the main/fixed guard. The spring should have a hook at either end that will go on these fixing points.
Dec 14, 2014 | Saws
What is the spring for in the 2000w makita circular saw
Other than carbon brush springs, the only other spring that I know of on a circular saw is for the blade guard so that it will automatically return to cover the blade after you make the cut. There should be a hook or a bend in each end of the spring and each end has a certain spot where it hooks so that it pulls the blade guard back in place.
Jul 13, 2014 | Makita Saws
How can I fix a jammed Ryobi miter saw blade?
Probably go a piece of wood between black and safety cover. Unplug from power before checking
Apr 30, 2014 | Ryobi 18 Volts Cordless Miter Saw 18v P551
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
May 01, 2011 | Makita 10" Miter Saw LS1030N
Replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Mar 24, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
I am missing the part that brings the guard back when you lower the saw blade
I am assuming that you have some type circular saw?
Most popular saws use a spring to return the guard,with the saw unplugged raise the guard and see if the spring is there(you may need to take off the blade) if it is not there,replace with proper spring.one end of the spring will hook onto the fixed 1/2 of the guard the other to the front of the moving guard(consult manual if possible).once this is done insure that the guard mover freely and is not in the way of the blade.Replace the blade in proper direction check guard again for proper travel,make sure everything has been re-tightened .
If the spring is there check for material build-up or debris that is causing
guard not to move,remove blade clean debris or obstruction,replace blade and check for proper operation.Also visually inspect where the moving guard is attached to the saw for any unusual marks or wear this could be a sign that some type of unsafe situation exists,if this happens refer to a pro to fix or buy new never use a saw without a properly working guard,it took 141 stitches to repair my friends leg.
Sep 28, 2009 | Hand Tools
I'm trying to figure out if I need to hold the lower blade guard up while the saw is running...there is no lock for it
No you do not need to holde the lower blade guard up. It should be spring loaded and move upward as it engages to piece being cut. depending on what you are cutting, you may need to hold it up to start the cut, but then it can be let back down while cutting. It is a safety feature designed to keep as much of the blade covered as possible during use.
Jun 27, 2009 | Ryobi 18v Cordless 5-1/2" Circular Saw...
Replacing the saw blade
my husband had trouble replacing the spring that goes in the plastic safety cover....he just eliminated the spring and it works just fine...thankyou for responding....L Martinez
Sep 27, 2008 | Makita 10" Miter Saw LS1030N
Saws Logo
383 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
