Question about Toshiba Qosmio G35-AV600 Notebook
3 tinny vertical lines across the screen - Toshiba Qosmio G35-AV600 Notebook
  • 107 Answers
If they are vertical it means that the pcb board at the top of the lcd is defective and the lcd needs to be replaced
Posted on Oct 03, 2009
My Sony Bravia KDL-46W-5100 has developed vertical lines. Any advice would be most appreciated.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 07, 2016 | Sony Televison & Video
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
Getting a vertical green line across my laptop screen
SOUNDS LIKE YOUR SCREEN IS CRACKED OR THE LED INSIDE THE SCREEN
Jul 14, 2012 | Computers & Internet
White line across black screen (setup mode?) model
if line is horizentle check vertical ic supply and out put capcitor if line is vertical check yoke wirsand cap 560k at horizentle yoke and any print brunt
Jul 03, 2010 | Quasar SP-2725 27" TV
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Toshiba Qosmio G35-AV600 Notebook Logo
222 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
