Question about Sub-Zero 632 / S
Is there a reset button? There is power to plug.Everything is shut down.
  • 358 Answers
There's an on/off swtch behind the top pannel by the compressors.But if there's not light inside or not display, everything completly dark , check if there's power through the cord , from the outlet to the connection box in the fridge.
Posted on Oct 03, 2009
How to reset Samsung duos e2222 simlock
shut down your phone
press volume up, home button and power button together
you will see the screen with option to
delete everything.
just delete everything and it will get reset.
Jun 04, 2016 | Samsung Cell Phones
Tip
CASCADING / CONNECTING TWO ROUTERS (WRT54G)
To properly connect a second router to a main router that acts as the gateway, follow the steps below.
1. Try to isolate your 2nd router first by disconnecting everything from it and connect a computer to port 1. Make sure that the power cord is plugged in.
2. Reset the router.
HARD RESET- Reset the device to factory default.
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
3. From the computer open an Internet Explorer browser and type 192.168.1.1 on the address field. Leave user name blank and type admin on password, you should be at the Setup Page by now.
4. Click on Setup Tab and change the LAN IP/Local IP addresses to 192.168.1.2 then hit apply/Save settings. Note that, it won't go back to the Setup Page, close your browser.
5. Access the new IP address of the through Internet Explorer browser. Type on the address bar http://192.168.1.2. Look for DHCP Server under the Setup Tab. Disable the DHCP then click on apply/Save settings.
6. Shut down the computer and power down the router. Now get a cat5 straight-through Ethernet cable and plug one end to one of the four ports at the back of the secondary router and plug the other end to one of the regular ports on the Main router. Then turn both back on. The 2nd router should be ready to provide connectivity now.
Hope this help everyone.
on Jan 15, 2010 | Linksys Wireless-G WRT54G Router
LG washing machine shuts off randomly, why?
only suggestion, next time it happens, unplug like you've done and then hold in power button for 15 seconds to see if that resets it.
Aug 30, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
How to reset lg g2 phone
It will erase everything Hardware factory reset Take your phone and turn it off just press power button and select power off.Wait while your device is shutting down.Then, press volume down button and power button together until the LG logo appears on the screen.When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.Once you do that, on your LG G2 the factory reset menu will be displayed.Press power button in order to agree and wait while the hard reset is being completed.
Aug 15, 2014 | LG Cell Phones
X501 completely shuts down during calls then restarts and says "preparing SD Card" and continues giving error notifications
You're going to have to do a hard reset...THIS WILL ERASE EVERYTHING ON THE PHONE (not the sd card)
Make sure the phone is off, hold the power button, volume down and the back button (third button from the left on the bottom) AT THE SAME TIME, hold and wait, once your in the back menu use the volume button to scroll down to factory reset use the power button to select, use the power button again to scroll down to yes, and power button to select, just wait, with will shut down and turn itself back on, takes about 5 minutes to restore function. (I worked for Cricket for a long time and I know the phone well)
Aug 13, 2013 | Cricket Wireless Cricket - Zte X501 Groove...
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Lennox outside unit fan will not stay running unless i reset the red button
You should replaced the fan motor along with capicator
Jan 10, 2018 | Heating & Cooling
Why does my htc wildfire randomly shuts off and on ?
Try to reset it and see if it fixes this problem but backup your data before doing this.This process will erase everything.
Performing a factory reset via settings
  1. Press HOME > MENU, then tap Settings.
  2. Scroll down the screen, and then tap Privacy > Factory data reset.
  3. On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
  2. Wait for the screen with the 3 Android images to appear, and then release the VOLUME DOWN button.
  3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
  4. When asked to confirm, press VOLUME UP.
Mar 14, 2011 | HTC Desire Cell Phone
Hp pavillion dv7 won't power on
Same issue - solved by disconencting everything (main battery, CMOS battery, RAM, hard disk and wireless card). Held in power button for 20 seconds (HP say this removes any electostatic charge on the main board). Reconnected everything and machine booted to Windows. Ran HP's onboard diagnostics and everything checked out OK.
Mar 30, 2009 | Computers & Internet
Acerpower SV PC will Not turn off
More information would help to resolve this issue.
Are you shutting down by selecting Start and shutdown or have you tried pushing the power button on push (not holding the power button)?
Try this:
Press and hold the power button in solidly for about 10 seconds. If it shuts down before you get to 10 just let off the power button. This should work, but may not solve the problem.
If you reboot it and still can not shut down from Windows, hold power button until it shuts down, unplug the power cord and disconnect everything from the computer other than the keyboard, mouse and monitor. With the power plug still unplugged, hold the power button in for about 15 seconds (this resets the power supply and can clear a corrupt BIOS).
Reconnect power and after booting, see if you can shut down from Windows.
If still no go, click Start, Programs, Accessories, System tools and select System Restore.
Follow the prompts and select a bold date back to a time before you had problems shutting down. That should do the trick.
Let me know if you get it fixed or if you need more advice.
Honest1abe
Jan 02, 2009 | AcerPower SV PC Desktop
Sub-Zero 632 / S Logo
207 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
