Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cana get the chain cover off - Husqvarna "Chain Saw - 16" Bar, 3 Hp
    President:
  • 2,220 Answers
That is agood thing... Grasp the forward most handle and pull it aft until it clicks. You just unlocked the chain brake. Try removing the cover now. Easier? Always ensure it is released before removing the clutch cover, Unlocking them once removed or worse putting them back together is most difficult! HTH
Lou
Posted on Oct 03, 2009
  • 990 Answers
Where the chain bar meets the motor there two nuts holding the cover and bar both on. Remove those and the cover should come off easly. Be sure to note direction on the chain as it has a right and wrong way it goes on. The cutting edge goes away from you on the top of the bar.
Part of the chain came off track
if it is a pole chain saw , and the chain came off, it is installed the same as any chain saw
undo the cover over the drive end , remove the blade and chain, loosen of the screw that adjusts the blade length
put the chain back on the blade , put the blade and chain back on the machine , replace the cover and do the nut up till it just touches the cover
adjust the screw until the chain is at a position where if you pull the chain off the bar the inside guide teeth are about halfway out of the bar guide
tighten up the cover nut
Aug 13, 2016 | Poulan pro pp338pt pole pruner - trimmer...
Install side cover on 455 rancher with chain break
Problem is you removed side cover with chain brake closed. You must open the chain brake to re-install the cover. You can do it with the handle. Put the side cover into position, put the handle into the fitting on the side cover. push the handle forward until you feel the "3" point connector engage. apply pressure to the handle and pull back until the side chain brake "Pops" open. Your Husqvarna dealer has a tool to open the chain brake if you are unable to get it open. Takes about 5 mins.
Feb 10, 2014 | Husqvarna Garden
Manual ryobi chainsaw
Chain replacement is basically the same on all chainsaws. Loosen the side retaining nuts on the cover over the chain. Now loosen the chain tension screw ( usually a flat headed screw) at least 4 full turns. Put the saw on its side with the blade up. Remove those side cover nuts and the side cover - the blade should sag as you remove the nuts. push the blade towards the engine, paying attention to the direction of the teeth on the chain. remove the chain and clean out the junk from behind the chain around the sprocket and from the inside of the side cover. The emergency brake band is located inside the cover - make sure you clean out the debris from around the band, tensioner screw assembly, and cover. Re-install the new chain, orienting the teeth in the correct direction. Re-install the side cover, making sure the tensioner pin goes into the hole in the bar ( blade). Slightly tighten the side nuts, then re-tension the chain until you can just pull the teeth off the bar. tighten the nuts, being sure you don't over tighten them ( a little past snug is good). Run the saw for a few minutes ( doing 1 cut will speed this step along). Loosen the side cover nuts and re-tension the chain, the re-tighten the nuts.
Hope this helps!!
Nov 26, 2013 | Garden
How to know a vehicle has timing belt or timing chain? this website http://www.timingchainorbelt.com/ is not working. please advise. Thanks a lot
Most car timing covers are either metal or plastic. the timing chains are usually in a metal sealed cover due to oil being used to lubricate the chain and gear assemblies and timing belts are usually in a removable plastic housing with some sort of access cover to inspect the belt, usually it is a two piece cover where as a timing chain is in a one piece cover. know-vehicle-timing-belt-or-timing-c3hyvbb5dw5lz1xfja5a3wpz-4-0.jpg
Aug 13, 2013 | Vehicle Parts & Accessories
Noise in the timing chain
May be its problem with timing chain and it has to be inspected and replaced.Or its possible that timing chain is got misaligned.
There are few help,links provided related to timing chain assembly and dis-assembly. Go through it and confirm proper inspecting of timing chain.
Click the required help link below:----How to Replace Timing Chain Cover & Seal on Audi A4 ? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-timing-chain-cover-seal.html
----------1982 Toyota Pickup: Set ignition timing, engine overheating, timing chain issue, dist off? http://whatisbyme.blogspot.in/2012/05/1982-toyota-pickup-set-ignition.html
----------How to Remove Timing Chain Cover and Seal on Toyota Previa?
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-cover-and.html
How to Remove Timing Chain and Gears on Toyota Previa?
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-and-gears-on.html
Ford Mondeo ST220 camshaft Timing specifications? http://technoanswers.blogspot.in/2012/02/ford-mondeo-st220-camshaft-timing.html
------------Replacing Timing Chain Cover For 2009 Ford?
http://repairhelpcenter.blogspot.in/2012/03/replacing-timing-chain-cover-ford-2009.html
Timing Chains & Front Cover Removal on 2008 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/timing-chains-front-cover-removal-on.html
----------How to Replace Timing Chain Cover, Chain, Sprockets, & Seal On Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-cover-chain.html
---------How to Replace Timing Chain & Sprockets on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
---------Timing Chain & Sprockets Replacing on Ford, Mercury and Lincoln? http://fordrepairhelp.blogspot.in/2012/03/timing-chain-sprockets-replacing-on.html
----------How to Replace Timing Chain & Sprockets on Ford Edge and Lincoln MKX? http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
------How To Replace Timing Chain, Sprockets & Front Cover on Ford Expedition and Lincoln Navigator? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets_356.html
---------Timing Chain, Sprockets, Front Cover & Seal removal for Ford Mustang? http://schematicsdiagram.blogspot.in/2012/03/timing-chain-sprockets-front-cover-seal.html
---------How to Replace Timing Chain on Buick LaCrosse? http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-on-buick.html
---------These details will help.For more help keep updated.Thanks.
Oct 15, 2012 | Cars & Trucks
Im having discover 135cc, an i want to remove the chain cover an put the chain strep, will it damage thr chain.
The chain cover is there to protect the chain from collecting dirt and and to save anything getting stuck in the chain eg. cloth which you are wearing.
The chain cover also protects the chain because when you leave the chain open to the elements you have to constantly oil the chain which dries out due to dirt, and in turn when you oil the chain too much the oil flows off the chain which would get on clothes etc.
Removing the chain cover does not damage the chain but the maintenance sure does increase trust me i have done it and I know, hope this helps
Mar 06, 2011 | 2007 Bajaj Discover
I have a 358351610 chain saw and need to find out how to remove the chain
Set the chain brake to off, then remove the fasteners on the right side cover where the chain drives from. This will release the bar which will slide back toward the engine and allow the chain to be removed. Note the direction of the cutting edge of the teeth. Clean everything including the two small oil passages that run from the large holes in the bar out to the chain groove on each edge of the bar. When refitting a new chain, back off on the chain adjustment screw (CCW) a few turns to allow the cover to fit to the bar properly. Fit the chain over the clutch sprocket, then insert the bar to the engine. Work the chain over the bar, then pull the bar outward to tighten the chain. Install the cover and the fasteners finger tight. Make sure the cover fits the bar properly. Tighten the chain adjuster CW so that the chain pulls up to the lower bar edge, but not so tight that you can't turn the chain by hand. Tighten the cover fasteners, then recheck the chain tension. The lower run of chain should be cutting as the chain moves toward the engine. Check the chain oiling by running the saw at speed with the bar tip near some cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Dec 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
What is the right way to time a 4cyl Chevy S-10 timing chain
1998-2003 To Remove:
  1. Remove or disconnect the following:
    • Crankshaft pulley and hub
    • Timing chain cover and gasket
  2. Install a bolt in the end of the crankshaft CAUTION
    Do not install the crankshaft balancer bolt or a bolt longer than 1 inch or damage to the crankshaft threaded hole will result.
  3. Rotate crankshaft until the number 1 piston is at Top Dead Center of compression stroke.
  4. Make sure that the alignment marks are aligned with the tabs on the timing chain tensioner. gm-03-22-611.gif
  5. Measure distance between hole in bracket and unworn surface of timing chain tensioner shoe. NOTE: If distance between the hole and unworn surface of timing chain tensioner is greater than 0.314 in (8 mm), replace tensioner, timing chain and sprockets.
  6. Remove timing chain tensioner bolts.
  7. Remove the timing chain, timing chain tensioner and camshaft sprocket at the same time.
  8. Remove the crankshaft sprocket using special tool J 22888-20A or equivalent.
  9. Remove crankshaft sprocket alignment key.
NOTE: If any camshaft components are being replaced to correct a noise problem, all camshaft drive components must be replaced.
To Install:
  1. Install the crankshaft sprocket alignment key.
  2. Install the crankshaft sprocket using special tool J 5590 or equivalent. gm-03-22-613.gif
  3. Compress the timing chain tensioner spring and insert a pin into the tensioner hole to retain the tensioner shoe.
  4. Install timing chain and timing chain tensioner (do not tighten tension bolts).
  5. Align the crankshaft and camshaft timing marks with the tab on the timing chain tensioner.
  6. Tighten the timing chain tensioner bolts.
    • Torque to: 18 ft lbs (24 Nm)
  7. Tighten the camshaft sprocket bolt.
    • Torque to: 96 ft lbs (130 Nm)
  8. Remove pin from timing chain tensioner hole.
  9. Remove bolt from end of crankshaft. CAUTION
    Inspect the timing chain cover for warping or damage. Replace if needed.
  10. Clean all timing chain cover mating surfaces.
  11. Install or connect the following:
    • Timing chain cover to the engine block
      1. Ensure that the gasket is installed properly in the groove in the timing chain cover
    • Timing chain cover and make sure it fully seated on the alignment dowel pins
    • Timing chain cover bolts
      1. Torque to: 97 inch lbs (11 Nm)
    • Drive belt tensioner
    • Crankshaft damper hub and the crankshaft pulley
Aug 17, 2010 | 2000 Chevrolet S-10
What is timing cover and if this goes do you need to replace timing chain and water pump
engine with 3.3 liters and 3.8 liters are equiped with timing chain.
the timing chain cover is the cover that cover and protect the chain
it must be seal because there is oil that come from the oil pan to lubricate the chain.
normally the cover does not go bad unless the chain broke or some thing hits it.
the water pump is out side and not involed in the timing chain or it cover
Mar 05, 2010 | 1996 Plymouth Voyager
HOW TO EMPTY
One of 2 ways, some you just take the top off, it will have a paper bag that you can toss and put in a clean and empty one. The other is the bottom is actually a bucket that unhooks so you can empty it. Hope this helps.
Nov 05, 2007 | Cana-Vac 511Q Central System Vacuum
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
74 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
