Question about Craftsman Garden
Starter turns but does not crank engine - Craftsman Garden
  • bargainbin2
    bargainbin2 May 11, 2010
    Does the starter turn the engine over?
  • 389 Answers
If this is a Briggs & Stratton engine, YOU DIDN'T SPECIFY, there is a plastic gear at the top of the starter that has worn out and needs to be replaced
Posted on Oct 03, 2009
2006 pt cruiser. It ran, stood for around 2month and won't crank up. I hear the fuel pump, the starter will not move, I replaced the starter and still no crank or move on the starter.
Can you hear a relay clicking when you turn the key over to "Start"? if not then a faulty relay could be the reason the starter motor is not cranking over. Is the starter solenoid "clicking in" but the engine not turning over? if so , can you turn the engine over by hand?
Oct 15, 2016 | 2006 Chrysler PT Cruiser
Engine want crank?
possibly a bad ground .
Mar 21, 2017 | Cars & Trucks
I have a 2000 toyota celica gts and it wont start or turn over the starter will make like a whinning sound but its not trying to crank the engine maybe its the starter but just in case its not anybody have...
Likely either the starter or solenoid. Solenoid is a combination of relay and actuator, pushing the starter's gear into engagement with your flywheel.
Oct 28, 2014 | Cars & Trucks
Why is the car not starting
not enough voltage in the battery to turn the engine over.
Sep 07, 2014 | 2011 Toyota Camry
How do i check the starter
When you say the engine cranks, do you mean the engine turns over but does not start? If that is the case I don't think you have a starter problem. The starter turns the engine so it sound OK. If it is turning slowly it could be a weak batter or starter. If in doubt you can remove the starter and take it to an auto part store like Auto Zone or Advance auto.
Jul 25, 2014 | 1999 Ford Escort
Jeep liberty 2008
turn on the headlights and try to crank the engine; if the lights dim out while you try to crank, then the starter is ok but the battery is too weak. just turning on the lights does not mean that the battery has enough juice to crank the engine; a starter pulls a lot more than lights. If the headlights do not dim out and it still won't crank, then the starter or a connection to the starter is your problem.
Feb 27, 2013 | Jeep Wrangler Cars & Trucks
2000 saturn LS1...ignition seems to be locked up. Battery functions, as well as the fuel pump, ignition coil, replaced the starter and crank sensor, and timing gears chain and water pump were all replaced...
Check power to starter motor and solenoid. If no power present on engine crank, then check ignition barrel, key and main fuses.If power present on cranking, but starter motor does not energize, then check starter connections and replace starter motor and solenoid if necessary.
Double check starter motor operation with starter removed from the engine. If it works, then check engine condition as this may be seized.
Nov 03, 2012 | Cars & Trucks
2004 ss siverado 6.0. engine does no crank
check to see if starter relay clicks while turning key to start position,if it does click check to see if voltage is reaching starter solenoid..if voltage at post on starter solenoid,but not cranking replace bad starter..(starter relay is located in fuse panel under hood..place finger on it while someone turns key to crank position ..should feel light click)
Dec 27, 2009 | 2004 Chevrolet Silverado
Won't crank, will push start and runs fine.
make shure your baterie haves abaut 13 amps
then check your starter solenoid make shure that curent is geting there wen you turn the key
Jul 13, 2009 | 2002 Isuzu Rodeo
Starter turns engine does not start
Hi;
Is the engine actually turning as well or is there a whirring noise ?
Jan 25, 2009 | 1998 Ford Aerostar
Garden Logo
230 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
