Question about Kenmore 15872 Dishwasher
Replacing seal First I need to know if I have the right model number.
    Scholar:
  • 146 Answers
What is the model number
Posted on Dec 29, 2007
Lubricate bearing
i dont know of anyone who sells bearing for motors find someone who sells hayward give them the model and serial number off the pump you need a new motor dont forget you also need new seals
Mar 01, 2014 | Hayward Pool & Spa
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Replace crank seals
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. !!
Feb 19, 2012 | Echo Garden
Water leaking from foam strip on the bottom of door
Be sure the seal around the door is clean and in position. If it is an older dishwasher then the door seal my need to be replaced. door seals can ordered on line if you know the make/model numbers of the unit.
Dec 17, 2010 | Dishwashers
My maytag jet clean dishwasher is leaking
I hope this helps. If this is your model... here is the replacement part. Or you will be able to find your seal here by putting in the correct part number or model number.
CLICK HERE
If you can replace the seal yourself you will save a lot of money!
Good Luck!
May 28, 2010 | Maytag MDB9600A Jetclean II Built-in...
Dometic RV refrig model NDR1292 seal on right door
Here's a link to number to call for info on replacement parts available.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Spare-Parts/
May 20, 2010 | Dometic NDR 1292 Refrigerator
Tappan oven door seal replacement
You will have to google the parts may be very hard to find but you never know what comes up .
Mar 16, 2017 | Tappan TEF242 Electric Kitchen Range
Dishwasher door leaking
You probably need to replace the door seal part number 902894.
Jan 31, 2010 | Dishwashers
Sound proplem
its the audio amp, its fried and needs to be replaced. match the numbers up and purchase/replace boards, this will solve your problem.
Nov 28, 2008 | Dell W2600 26 in. LCD Television
Door seal on GE Adora Washing Machine
After going through 2 different places that sent me the wrong part, I finally got the right boot seal today from Home Depot Appliances. I just gave them my model number and they overnighted the new boot seal to me, and for only $100. To call a GE repairman, it was going to cost $70 in the trip and $170 for the seal. Rip Off. We did it ourselves. Saved a lot of time and waiting.
Jul 21, 2008 | GE WSXH208A Front Load Washer
Kenmore 15872 Dishwasher Logo
50 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
