Canon FAX-JX200
Problem for Canon FAX-JX200
6000
By mom3times on Dec 21, 2007
my fax says check 6000
Same Problem
Feb 14, 2009
-   Not working -   Guest
Feb 25, 2008
-   may  fax mashin is writing on display !! check!! 5100-   Guest
Best Solution
posted on Jun 19, 2008
Very Helpful)
craigob
Rank: Apprentice
Rating: 100%, 11 votes
I had this Check 6000 when I first got the machine. The problem was that I did not lift up the top cover (where you put the paper in). As a result it locks the carriage and creates this error. Lift up the cove at the top of the machine, then turn the machine off and on again and 'Hey presto" your problem is solved.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Feb 04, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
it is related to carrage motor drive assembly it is on front to left side pls heck its connector.
Nikhil Chachapara
Solution #3
posted on Dec 28, 2007
Somewhat Helpful)
Kaoeria
Rank: Wiz
Rating: 79%, 40 votes
Turn OFF the machine, and unplug the power cord of the machine from the power supply. After a while (while as in maybe an hour or so), plug the power cord of the machine back in and turn ON the machine. If this does not work, turn off the machine, unplug it from the power (power meaning wall/ac pluggin, if hooked into a computer/phone line, its fine), and hold down the power button of the machine for a minute straight. Then allow it to sit unplugged for a while, and try again.
For this machine, check 6000 isnt a normal occurance. Its not an actual error to be fixed by yourself. Just make sure you don't have a paper jam, new ink, printer head is clean (the printer head is the thing between the ink, and the paper, usually a microchip covered with a clear, plastic coating underneath where the ink sits).
If the same error occurs, contact a Canon service representative for a solution. It may need to be fixed....
Was this helpful?
Yes
No
Solution #4
posted on Sep 22, 2009
Very Helpful)
stanomukuha
Rank: Apprentice
Rating: 100%, 1 votes
canoon fax displays check 600 whats the problem
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon FAX-JX200
Questions and Unsolved Problems for Canon FAX-JX200
Do you recommend Canon FAX-JX200?
Answer
Answer
hi cant set up my new fax machine to recieve faxes its a jx500
Answer
Kaip siųsti faksogramą iš FAX-JX500
Answer
I cannot ge into the menu to set up the phone. On screen it says Line in Use. Ive checked and its... (More)
Answer
i have anew my fax-jx200 machine and its giving me error " check 6000" how do i fix it
Answer
I have a Canon JX200, and the message displayed on LCD is CHECK 5100. I've changed the cartridge,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon FAX-JX200:
Top Fax Machine Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Fax Machine Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
