Question about Saeco RIO Vapore
I have a starbucksw Barist esspesso machine. The handle that holds the coffee needed cleaning, and a little spring popped loose. Do you know where it might go?
  • 3 Answers
Http://www.partsguru.com/user/Barista%2005.01.pdf
Check here, all the parts are listed, it apparently may be the spring for the boiler seal.
Posted on Feb 10, 2010
Gaggia Baby filter is stuck!
The filter is stuck on the group head of the machine only by the force of dry coffee which acts like glou and since on the portafilter is secure by a wire spring which is probably loose and couldent hold the filter in place.
So all you need is a pointing screwdriver with edge like a nail or similar and use it on the filter try to level it out and by a little force try to move it and get unstuck. After that you can clean also the coffee remaining's on group head also.
In order to avoid this in future you will have to clean the portafilter from machine after you will make a coffee, replace the portafilter spring with a new one and clean the grouhead and grouphead gasket often with grouphead brush. You may need also to buy cleaning grouphead powder and backwash blid filter to perform backwash frequent. All these cleaning and parts you can easily find in eBay.
Jun 09, 2013 | Gaggia Baby Espresso Machine
Tip
My vienna does not make coffee or is very slow
Hi
That is usually a pluged or restricted brew head.
That usually means that you are getting a restriction in the brew head from oils and fine coffee grounds.
Remove the brew unit. Holding the handle, on the top left side is the brew head, there is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2 screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk or crystal ball). Do this over a towel to prevent loosing small pieces, mainly the crystal ball.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON'T use the key to install the screen, use your fingers.
Once the screen is out, look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it
on May 07, 2011 | Saeco Vienna SuperAutomatica Coffee...
Brew group taken apart and small glass ball fell out from where I don't know and I need to get this back otherwise the water brews into the grout draw. HELP
HI This is the instructions for cleaning the brew head. If you follow these instructions you will get everything back in the proper way and you can make coffee again. Remove the brew unit. Holding the handle, on the top left side is the brew head, there is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2 screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk or crystal ball). Do this over a towel to prevent loosing small pieces, mainly the crystal ball. Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON'T use the key to install the screen, use your fingers. Once the screen is out, look at where the screen was. There are 2 holes. A big one in the center and a small one to the side. With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side. Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball. Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Jun 17, 2011 | Saeco Vienna SuperAutomatica Coffee...
I have a Gaggia Titanium. It has stooped making coffee. It brews and grinds but no coffee comes out. If I open the steam know coffee colored water comes out. No water comes oiut when I rinse it. I...
If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run normally, your grind is to fine. Turn the grinder knob to a larger number. It takes 3 times to change to the new grind.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door. 2 screws hold it to the top. Remove the 2 screws while holding the manifold. Once they are removed, lift the l assembly off (becareful, there is a spring and inside a steel ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the steel ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
Now use air to blow back through the opening where the steel ball was to clear the opening. Once its open, clean then reassemble. Brew unit on towel right side up. Drop the steel ball in first. Then the spring.
Then place the manifold on top of that with the pipe towards the door. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this.
Jan 02, 2011 | Gaggia Titanium Espresso Machine
I have a new bread maker . When I unpacked it, the bread pail is secured in the machine. Normally, I lift the handle of the pail, twist it and out comes the pail. This is my first Cusisnart, and the...
Hi, those function as little spring clips to hold your pan in. There is no twisting of the pan with your new machine. Just pull straight up with a little "pop" (use both hands and just pop up on the handle) and your pan will pop out. When you bake your first loaf just push the pan straight down until the pan clicks back into place under the little clips and you are ready to bake!
Oct 20, 2010 | Cuisinart CBK-200 Bread Maker
After using oily coffee beans the machine drops one drop at a time how do I clean the coffee grinder and drip system alos it says after the rinsing cycle 'ventilate' how do I ventilate.
Hi
The ventilate is just opening the steam valve for just water. Don't push the button for steam. Your grinder needs to be a little coarser. Turn the big know in the bean hopper to a larger #, about 2 to 4
# higher.
You need to clean the brew head in the brew unit.
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front, towards the door (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring with a black seal (don’t loose it or your out of luck).
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON’T use the key to install the screen, use your fingers...
Once the screen is out, look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Then the spring with black seal down.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the handle side. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Install in machine and test
Jun 26, 2010 | Solis Master 5000 Espresso Machine
The coffee is barely dripping out of the machine.
Check the grind, that may be too fine, then check the brew unit, find the shower screen under the red oring and clean shower, follow tube from shower and red o-ring, look for 2 screws and remove carefully, you do not want to loose the spring and seat sometimes a ball. clean that chamber.
Mar 28, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Filter Basket pops open while grinding and brewing
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
Jul 14, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Handle came loose on Krups carafe
Easy fix. Pry off the cover on the handle to expose two philips screws. Secure the screws back in and pop the cover back on.
Jan 15, 2009 | Krups Aroma Control 198 Coffee Maker
No crema
Sounds like the handle where you put the coffee in needs replacement, if you leave the machine on for long periods with the handle on there is a metal spring inside with plastic parts that regulate the pressure in the tamping basket. 9 BAR is the desired pressure to produce crema. the plastic parts can melt and the spring looses tension. If you place the handle on, lock it, the it should shift slightly backwards on its own if you have to help it I have bad news replacement time. I have seen replacement from 25.00 - 90.00. I have two classicos and already replaced one handle and have to do the next. It could take one time of leaving the machine on all day. Good to get in habbit of turning off the machine immediately after use let it cool slowly attached to unit and clean it when you get home. Immediate cleaining in cold water could make the spring fatigue faster and also cause this problem.
If you are brave and can remember where parts were; take the three screws off where the coffee comes from handle slowly separate the parts and you will see if plastic melted, is distorted or spring is like mush.
Here is the saeco parts diagram and parts ordering site but I warn you its the most expensive
www.saecoparts.com/SaecoEspressoClassicoBodyparts.html - 70k -
Jul 08, 2008 | Saeco Classico Espresso Machine
Coffee Makers & Espresso Machines Logo
135 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
