Question about Boating
Winterization for 1992 bayliner trophy
What all must a person do to winterize a 1992 bayliner trophy for the winter out of the water. -40 winter stored outside under a tarp. It is a cuddy cabin 22ft with a 3.0 L merc gas and a merc leg. Has its own engine cooling system. I know I have to add antifreeze to the head and pull the plug to drain the keel but what about bilge pumps, fish wells, aftercoolers or whatever it has and needs. Is there anything special to the engine, hull, electrical that should be done
  • wilkit Oct 04, 2009
    this advice talks about a product to reduce the time it takes to winterize not how to winterize
  • 986 Answers
The bilge pumps as long as they are dry its no problem, fish wells and lines should also be dry. Everything else is not really a issue. You can have the boat shrink wrapped for the winter to keep the water out but a quailty cover and a run off stand would do the same as long as you keep it standing up.
Just make sure she is clean and ready to store, drain the gas, and cover the tires for protection.
Best of luck
Posted on Oct 04, 2009
    President:
  • 1,723 Answers
You are on the right track so far. Just be sure and get the anti freeze in the engine. Drain any water left from the bilge pump so it's dry. Rather than going on here, I'm giving you a couple links with some good tips to follow...
http://www.minutedrain.com/faq.htm
http://forums.iboats.com/showthread.php?t=158078
Posted on Oct 03, 2009
How to winterize 175 mariner outboard motor
Take a look at these instruction videos.
How to Winterize an Outboard boat, step by step guide in ...
9k=? 11:25 https://www.youtube.com/watch?v=x217iM77Qjc Oct 30, 2012 - Uploaded by Warren Hardy A detailed step by step guide to winterizing your outboard boat motor for ... most 2-stroke outboards ...
Winterizing Your Boat: Step 2 The Engine & Lower Unit ...
9k=? 10:01 https://www.youtube.com/watch?v=5kiOms2f4gg Oct 6, 2009 - Uploaded by West Marine How to Prepare Your Boat for Winter - Step 2 in the five step process on How to Winterize Your Boat: The ...
How to Winterize a Four Stroke Outboard Motor - YouTube
9k=? 2:44 https://www.youtube.com/watch?v=PRBnwYk8_Yk Nov 7, 2012 - Uploaded by boats.com Four stroke outboard motors are by far the most popular on the market. But there's a lot of confusion about ...
How to winterize your outboard
www.classicglastron.com/gl-outboard-winterizing.htm For smaller outboards, the simplest way to flush your outboard is by using a large ... water or purchase a set of "ear muffs" (available at your local marine dealer).
How to Winterize an Outboard Motor - Adventure
adventure.howstuffworks.com/outdoor.../how-to-maintain-a-boat4.htm ... the winter and prolong its. Learn how to properly winterize an outboard motor. ... Buy lubricant, oil, and fuel conditioner at a marine store. Time: about 2 hours.
Jan 09, 2016 | Boating
Why is water dripping from our 2008 ford escape condenser drain under the hood in the winter
if the vehicle is in defrost it will turn on compressor that is normal so the clutch is activated in the winter and doesnt seize from lack of use in 3 or 4 months of winter season
Dec 11, 2015 | Ford Cars & Trucks
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
Cannot find the water pump to winterize 2010 Forest River Sierra. I can hear it running but am unable to locate it. The bypass valves are in the correct winterize position but the antifreeze will not go in...
You don't need to find the water pump. Make sure your water tank is empty before adding RV winterizer to the water tank. Run each faucet in the RV with bypass valve NOT in winterize position until you see the antifreeze begin to come out of the faucet. Do this for both cold and hot water side for each faucet. Then move bypass valve to winterize position and run for a few seconds.
Oct 29, 2013 | Forest River 2009 Sierra 355QBQ
How do i winterize a 1990 4387 bayliner motor yacht
Yes--- it involves finding EVERY drain plug in the engine and exhaust system, running some preserver oil thru the engine JUST as it runs out of gas and mixing the right amount of gas preserver to last the winter. THEN there is the fresh water system which needs a non poisonous antifreeze and proper draining along with the black and grey water tanks being serviced. If it has a hot water system, it needs to be drained.
Then there is the trailer bearings which will be full of water if you are going to store on the hard they will be full of water from the retrieval (don't get be started on bearing buddies) No body knows how to use them properly.
Oh ya- you need to service the lower unit for leaks and new oil, and check the u-joint boot for water and bad U-joints and grease the intermediate bearing.
But don't forget the drain plug or all this work will be for nothing as you will find a boat full or rainwater and a bent trailer.
Sep 04, 2012 | Boating
Heater and defroster don't work well
Connie this sounds like your thermostat in the engine is stuck open not letting the water stay in the engine block to heat up. The fix is to replace the thermostat with a new one that will allow the water to stay in the block to warm up. The typical symptoms of a stuck open thermostat is that the air will blow somewhat warm but never hot in the winter time, but it will take a few miles for the air to warm up at all. I would check with the dealership and find out what degree thermostat to replace it with. I run a 180 degree in the summer and a 195 degree thermostat in the winter just to have hot heat in the winter. I hope this helps
Nov 20, 2011 | 1992 Honda Accord
Need an undercarriage protection for our 2003 chevy blazer - cant find one!
There are any number of commercial protection products available over the counter.. of any auto part store, or online.
In my own humble opinion... Your best protection is regular washing with clean water, and some WD40 on all unpainted surfaces. Any coating you put on will eventually trap moisture and contaminants under it, causing corrosion faster.
Easy way to prevent undercarriage rust is to power wash the entire undercarrage, then spray the entire undercarriage with WD-40 before the onset of winter.
WD-40 displaces water, helping to keep rust under control. Suprisingly, it doesn't come off as easily as you'd think in wet winter driving.
Use use two medium size cans of WD-40 to do all undercarriage, making sure to spray every nook and cranny (but avoiding the brake rotors/pads) until it is saturated.
Believe it or not, one good coating will last all winter--at least enough to prevent rust. Each spring, use a high pressure sprayer to clean the undercarriage and reapply a new coat of WD-40 for the spring/summer/fall months.
Jan 09, 2011 | 2003 Chevrolet Blazer
What kind of oil does it take
In the summer it's best to use a heavier weight than you do in the winter. I usually use 10w/30 or 10w/40 in the summer, but in winter i use 5w/20 or 10w/20. As far as brand, it's really a personal preference. I still use castrol in my personal vehicle.
Apr 06, 2010 | 2004 Ford Taurus
Suddenly a non starter
did you leave gas in the tank over the winter thats not good on it but i would say spark plug check it and the wire
Apr 05, 2010 | 1992 Triumph Trophy 900
In cold weather engine/car vibrates
is it at idle if yes change your idle air control valve.
Dec 17, 2008 | 1992 Ford Club
Boating Logo
75 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
