Question about Velodyne DD-10 Subwoofer
I hear noises when DD-10 is turned on.. even without signal to i
I tried to unplug the RCA, leaving only the power cable. Noise still coming out from the sub.
I switched power cords, changing to different outlets, but those dont help.
appreciate anyone that can suggest a solution.
  • 124 Answers
If it is a low level white noise, you may have some form of RF noise that is being picked up by the driver mounted servo system.
Then it could be something else as well.
Best to contact Velodyne to see about service for your unit.
Posted on Nov 11, 2009
For a while, tv would only come on if completely unplugged for several hours and would then work fine. If you tried to turn it back on without doing this, it would just make a lot of noise. Now, even...
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 04, 2015 | Toshiba 23HLV87 23 in. LCD Television
The tv wont turn on all the time-the tv will make a noise like it coming on then the power button blinks and it doesnt turn on-Then it might come on after 20 minutes or 10 hours.
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Have a 06 rca hd61w66 powers on but screen dont come on! makes a weird noise an shuts down! like sumthin is tryin to start up but cant! n i took back off tv to see an the noise comes from a boared on the...
Thats the Power Supply. You need to call a service man, please disconnect this unit from the Power, It is dangerous to leave it plugged in. what is happening is the set has developed a serious fault, to avoid a fire or explosion, the PSU has shut down the set. that noise you hear is the power supply struggling against the fault. trying to start. Please for safeties sake, get a "Quote" from a reputable, preferably an RCA recommended service centre.
Mar 28, 2010 | RCA HD61W66 61" Projection HDTV
GETTING INTERFERANCE FROM TRUCK,SQUELCH IS TURNED 3/4 ROUND TO STOP NOISE .HAVE TRIED CHANGING BOX,ARIEL,CABLE AND MOUNT,ALSO TRIED TAKING POWER STRAIGHT FROM BATTERIES, NOT SURE WHAT ELSE TO TRY?
Try this. While with the engine running and radio on, while you hear the noise, disconnect the antenna wire from the radio. (DO NOT KEY IT).
If the noise is gone, then the noise is coming in from the antenna. A new location may be needed.
If the noise is still there then its coming in from the power line. You need to get a ground loop isolator. Make sure its not one for RCA cables. You need one for the power line. It connects to your power source, and then your radio connects to it. this will take most of the noise out.
Oct 23, 2009 | Midland 1001Z 40-Channels Base CB Radio
Noise in my car amp.
sounds like you have a bad ground going to your rca's. try running a wire from ground to the shield of your rcas and see if the noise goes away.
Apr 19, 2009 | Rockford Fosgate Power 1050S Car Audio...
Humming noise in amp
You must break it down through a process of eliminating items. With the system running unplug the RCAs from the amp. Do you still hear the noise? Try turning the gain down on the amp a bit and increasing the subwoofer level on the head unit instead. Make sure you have a low pass crossover set (probably below 80Hz).
Does the noise change with engine RPM?
Try a different RCA cable. I find that most times noise filters will make the problem worse not better. If none of the above things work, check that the grounds within the car are good, battery to frame, to engine block and chassis. Sometimes a bad vehicle ground is the cause. If all else fails, hook it up to someone else's system and see how it works.
Oct 07, 2008 | Car Audio & Video
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
Audio noise
Do you hear the noise from the speakers or the back of the set. If its from the speakers you could have a weak signal that is making the streo demodulator react and make funny noises. Try going into the audio menu and switching the stereo to mono or taking it out of expand mode. If its vcomming from the back of the set then sopmething like a high voltage or small coil is "singing" and not alot you can do except have the set repaired by a local repair person. Good Luck
May 11, 2006 | RCA F27665 27" TV
Velodyne DD-10 Subwoofer Logo
264 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Matthew Spark
Matthew Spark
Jerry Greenberg
Jerry Greenberg
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
