Question about Whirlpool Duet GHW9150P Front Load Washer
What does the F 20 code mean? - Whirlpool Duet GHW9150P Front Load Washer
  • 530 Answers
The fault code F 20 is for "No water or Insufficient water supply". There are a few possible causes.Even brand new machines can give this code if one of the internal hoses gets kinked.
There are some things you can check before resorting to a service call. First check all your supply lines. Make sure the valves are fully open and that the lines are not kinked or pinched off in anyway.
The next step would be to remove the supply lines and using a bucket, check the water supply. Make sure the pressure is adequate.
After you have checked theses items clear the code by pressing Pause/Cancel twice. If there is any water in the washer it should drain and unlock the door after 3 minutes.
Unplug the washer and then plug back in. Run a wash cycle and see if the code returns.
If it does the next place to check will be internal.
The first item is the small supply hose that runs between the pump and pressure switch. Over time it can become plugged up. If you are comfortable with working on this simply remove the top or back section. The pressure switch is located near the top of the washer. It is about 4 in. round and has wires and a 1/4 inch black tube attached to it.
Remove the tube and clear any obstructions. Then reassemble and test again.
If the code returns it may be a bad switch or a clog in one of the main internal supply lines. From there if you would like to continue repairing it yourself please let me know and I'll try and talk you trough it step by step.
Hope this helps. Good luck.
Posted on Oct 03, 2009
Testimonial: "Thank you very much. You were very helpful. Louise"
Why does my 1997 Plymouth Voyager shut down while driving after 20 mins?
Well code 1698 means the engine computer could not communicate with the transmission control module. I doubt that would kill the engine, but there could be a wiring problem somewhere.
It could be a faulty relay too.
Jul 27, 2014 | 1997 Plymouth Voyager
What is code blinking 20 on noritz tankless hotwater heater N_069M
The error is a HIGH LIMIT THERMAL ERROR. That means Calcium buildup has appeared in the unit. It is also called scale. To clear the error you have to power it off. That is done by the circuit breakers. You should descale the unit first though.
Jul 26, 2014 | Noritz Water Heaters
1998 318 code 18 and 20 abs light on have changed front left speed sensor light still on
code 17 is the control unit may have bad relay or connection or unit electricaly no good as far as code 20 it does not exist, you may mean 120 that could be connections at wheel abs tone rings or sensors.
Jan 21, 2010 | 2003 BMW 325
Code F-20 what does it mean?
“F20” on display
(Water Inlet Problem—no water or insufficient water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Oct 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
1997 FORD CODE P1000
a p1000 code means that the system has not run all checks since last memory erase. in other words after a code erase this code is set until the car has been driven for 2 drive cycles which is 20 to 25 miles then 20 to 25 miles again.
Apr 20, 2009 | Ford Taurus Cars & Trucks
Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Nov 19, 2008 | Panasonic Workio DP-3530 Copier
Error code E:62:20 meaning
errorE:62:20 related to lens unit stuckup or gears problum repairable
Apr 14, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
