Question about Fuji FinePix S1 Pro Digital Camera
Need to find a battery door for the finepix s1 pro it the one that goes on the bottom of the camera for the cr123 battery
WebTeligent
  • 42 Answers
SOURCE: Fuji Finepix S1 Pro fE E blinking when turned on?
Might Help:
Notes on G-type Nikkor and other CPU Nikkor lens
The G-type Nikkor lens has no aperture ring; aperture should be selected from camera body. Unlike other CPU Nikkor lenses, aperture does not need to be set to minimum (largest f-number). CPU Nikkor lenses other than G-type Nikkor lens have an aperture ring. Set the lens aperture to its minimum and lock. When the lens is not set to its minimum aperture setting and the power switch is turned on, "fEE" blinks in the control panel and viewfinder and the shutter cannot be released.
Posted on Nov 09, 2007
spystyle
  • 12 Answers
SOURCE: Err message
Have you tried using a different memory card or formatting the memory card? My S1 was acting weird until I formatted the memory card using my computer.
Posted on May 02, 2008
SOURCE: hello guys fuji film s1 pro problem
I have used the same lenses for years, still get the same message as well.
Posted on Jul 29, 2008
  • 4 Answers
SOURCE: HELP! need to know why my Fuji FinePix S1 pro flashed "f EE" on the LCD screen?
Thia error is caused by the use of a non-AI lens, or that the F-stop is not set to the lowest setting.
If the lens can support light metering on this camera, then the solution is to set the F-stop on the lens to the smallest number (ie, 2.8, or 3 or whatever the smallest number is.)
John C. Vincent
yellowcaseartist.com
Posted on Mar 12, 2009
SOURCE: Fuji FinePix S1 Pro Digital.
camera displaying FEE
Posted on Mar 08, 2010
I haven't heard back yet. Alol I needed to do to correct err message was replace AA batteries. Please send my operators manual.
Please CLICK HERE TO DOWNLOAD the operators manual for Fuji FinePix S1 Pro Digital Camera .
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site.
Oct 11, 2011 | Fuji FinePix S1 Pro Digital Camera
Fuji s1, when I power up I get "Err" message on top LCD screen. Batteries are all freshly new.
"Err" message relates to the batteries.
If constantly lit, It's the AA batteries. When flashing, it's the lithium batteries. It can also be the tiny switch in the media door. Try activating it gently with a pointy object to see if the message disappears.
Dec 05, 2009 | Fuji FinePix S1 Pro Digital Camera
Fee flashes even though apeture ring is set to
I have the same prolem. I think it has soming to do with the Meter coupling lever , it protrudes top of the Nlkon F-mount on the front of your camera. it may be need of repair
Sep 12, 2009 | Fuji FinePix S1 Pro Digital Camera
My fuji finpix s1 will not pull up the menu, nor can I take any pictures however the automatic focus works, the function lcd lights up but it will not work either.
rdp19 did not mention the ERR msg.
I had the same problem, however after messing with it the ERR message is up.
If RDP19 gets this, did you get it fixed.  Where and what cost?
Jan 26, 2009 | Fuji FinePix S1 Pro Digital Camera
I strongly recommend you use a memory card reader to solve this problem.
The cause is likely a bad USB cable, USB port on the Camera, or low battery.
A USB memory card reader will work around any of those causes.
Jul 20, 2008 | Fuji FinePix S1 Pro Digital Camera
Hello guys fuji film s1 pro problem
From the Fuji S1 Manual:
F-- (Flashing) or (lit in M Mode)
Cause:
The lens mounted is not a Nikkor lens with built-in CPU or no lens is mounted on the camera.
Solution:
Use a Nikkor lens with built-in CPU (excluding IX Nikkor lenes). (Note that pictures can still be taken in M mode.)
Jun 06, 2008 | Fuji FinePix S1 Pro Digital Camera
Err message
This problem is caused by the plastic memory card door.
There is a door that hides the memory card on the back of the camera.
The door has a small plastic part on the left side that when the door is closed fits inside the camera.
When the door is open this part is exposed. It is right next to the "^" in "^ PUSH TO EJECT"
If you place one drop of superglue on the top of this little plastic part of the door(when open) and let it dry overnight(LEAVING THE DOOR OPEN OVERNIGHT.)
This will slightly build the plastic up about .05-1mm.
The problem is caused by the plastic part being about 1mm too small, liking resulting from normal wear.
I have tested this, and it seems to have resolved my issue with the S1 Pro I bought on e-bay
John C. Vincent
May 01, 2008 | Fuji FinePix S1 Pro Digital Camera
EEE Error
3 reasons u get an "err" msg are
1. lens aperature not at smallest stop (f22 for example) turn aperture ring to smallest aperture setting or largest number
2. No memory card, or card not formatted or the magnetic latch of the memory card is sensitive try closing it firmly , or try changing memory card may it is damaged by force pullout.
3. weak batteries (4- AA and 2- CR123)try changing them.
4. Try changing or taking out lenses.
i hope something work out for u lemme know
Jan 16, 2008 | Fuji FinePix S1 Pro Digital Camera
FinePix S2 Pro
replace the cr123 batteries. If one of them is down on voltage you will experience exactly the symptoms you describe.
Jan 15, 2008 | Fuji FinePix S2 Pro Digital Camera
Camera shuts down when the flash is opened
the flash circuit of the camera is short. the moment you switch on the flash it drops the supply voltages of the battery. you have to show it to a repairer.
Nov 17, 2006 | Fuji FinePix S1 Pro Digital Camera
Fuji FinePix S1 Pro Digital Camera Logo
46 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
