Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Vista. Formatting my USB Flash Drive
I have Vista. Whenever I try to access the USB Flash Drive, my laptop keeps telling me to format it. I do what it says, but a couple minutes later its says "windows was not able to complete the format". Please help.
    Guru:
  • 597 Answers
I think the reason it was telling you to format the flash drive was that it couldn't read the FAT table on the drive probably because the drive was damaged. Stands to reason that when you try to format it, because it's damaged, you can't do so. I have seen a lot of bad sandisks. I think a lot of people pull them out of the USB port while it's still being used without "Safely Removing Hardware" and it damages them. The following article may explain why.
The "safely remove hardware" bit is used because removable drives like USB sticks and camera memory have a file system on them just like your hard drive does. Most of these drives are small (<= 32 GB) so they use FAT16 as the file system type. FAT16 is an older file system and writes to the disk are simply done on demand. If the power to the machine is cut or the drive is simply yanked out during a write, this will result in incomplete data and possibly a corrupted file system on the drive. The "Safely Remove Hardware" bit calls for all programs accessing the drive to complete whatever reads/writes they need to as the drive will be removed. When all I/O is complete, the OS removes the drive from its list of usable drives and then pops up the bubble telling you it's safe to remove it.
If you formatted your memory card/USB stick yourself and put a journaled file system like NTFS, ext3, XFS, ZFS, HFS+ or ReiserFS, then the removal is different. All writes to the drive are first written to a journal, which is a temporary space on the drive. Once the data is written to the journal, then the data in the journal is written to its final location on the drive, overwriting the original data. Yanking out the drive will cause the following things to happen:
1. Yanking the drive out before the data has been completely written to the journal causes the original data on the drive to remain safe. The changed version of your file that was being written to the journal is lost as the FS sees that there is an incomplete write to the journal and flushes the journal the next time the drive is accessed.
2. Yanking the drive out after the data is written to the journal but before it can be completely written to the file system results in the partially-modified file in the file system being replaced with the good copy on the journal the next time the device is accessed. The user would never know that the final write never completed.
3. Yanking the drive out before any writes to the journal occur or after the data from the journal was successfully copied to the file system cause no issues as the drive is idle.
Safely removing a disk with a journaled file system causes the same actions as with the non-journaled file system but will also cause the disk to make sure that all of the journaled data has been written to disk successfully. Journaled file systems are more modern and much more reliable than non-journaled file systems. They still should be removed safely, but the consequences for not doing so are basically that it takes a longer time to access the disk upon the next access (due to journal-file comparison and flushes.)
The reason that journaled file systems do not commonly appear on UBS sticks or camera cards is because of Microsoft. Most people run Windows computers and Windows computers can only recognize FAT16/FAT32 and NTFS file systems out of the box. ext3 support can be easily added via a driver, but the other file systems require some external program to access (ReiserFS) or are completely unreadable in Windows (XFS, ZFS, possibly HFS+ as well.) NTFS isn't used on removable devices because it is covered by Microsoft patents while the FAT file systems are direct descendants of the original DOS file systems and are in the public domain. Device makers would have to pay MS a royalty fee for every device shipped if it was pre-formatted with NTFS. So the device makers have a few options:
1. Ship the drive with FAT formatting for free even though it's sub-optimal.
2. Ship the drive with NTFS formatting and pay MS $0.25 (IIRC) per unit shipped.
3. Ship the drive unformatted for free and require the user to format it on their computer, where they can format NTFS for free. This axes out-of-the-box working ability.
4. Ship the drive with ext3 for free and require that the users download the Windows ext3 IFS driver for free. This also axes out-of-the-box working ability and renders the device unusable on computers where the user doesn't have admin access to install the ext3 driver (work computers, public terminals.)
Most manufacturers want easy-to-use and cheap rather than good so they ship FAT-formatted drives. I leave mine formatted as FAT as cameras won't support anything but FAT16 and since I don't run Windows, I can r/w to FAT but basically only read from NTFS (write support is VERY limited.) I'd simply format my USB stick ext3 and be done with it, but I use my drive a lot on university computers and I highly doubt that the techs would install the ext3 drivers for me.
Posted on Oct 03, 2009
How to format usb that says it has 8mb capacity.
To Format Any Flash (USB) Drive
WARNING: This will permanently remove ALL data from your flash drive.
1) Insert the flash drive into a working usb port on your Windows PC.
2) Open "My Computer" in Windows XP or eariler OR "Computer" in Windows Vista/7
3) Right click on the Flash Drive (Usually labeled "Removable Disk")
4) Click "Format..."
5) Ensure that file system is "FAT32", Volume label is a name of your choosing, and that "Quick Format" is unchecked
6) Click "Start"
7) Windows will warn you that all data is about to be deleted. Click OK.
8) Once the format is complete, Windows will produce a pop-up window telling you so.
You now have a blank flash drive.
Apr 12, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hello, i am not able to format my transcend 8gb pen drive. whenever i format this pen drive after a few second's i got a message "WINDOWS UNABLE TO FORMAT". Properties shows used space 0 bytes and free...
Try it on another usb port..or If the windows can't format try formatting it from the command prompt if it's not working than must be pendrive.. i think there's no problem with other pendrives.. or the one that you have
Aug 18, 2010 | Computers & Internet
My usb stick needs to be formatted for pc but i cant
you can try format recovery software like asoftech data recovery. You can see
Recover formatted files
It tells the steps how to perform format recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
Apr 04, 2010 | Computers & Internet
Pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Aug 17, 2009 | Transcend (589307) Media
Not formatting
I had the same problem with my 1GB SONY MicroVault Clip flash drive. Hardware and the drive shows up on Vista, but it refuses to open or format it.
1) IT MANAGED TO REFORMAT NICELY ON WINDOWS XP!!!! So try this, or
2) When the Micro Vault does not operate well, please download the format software from a "download" button and re-format the Micro Vault. http://www.sony.net/Products/Media/Microvault/products/usm-l/dl.html
hope this helps guys!! :D
Apr 23, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Can't access my Verbatim 2.0 Flash Drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 19, 2009 | Verbatim USB 2.0 HD DRIVE 12GB STORENGO 12...
Need to format flash drive, but want to keep data
try 2 get a software caller get data back. format your flashdrive and retrieve back the data using that software. software is readily available on torrent site just download it. t.y.
Jan 31, 2009 | Computers & Internet
My 8gb micro cruzer flash drive has been unformatted.
i)let me suggest i ur able the flash drive icon when you go in desktop or my computer then right click on that drive and click the option format and follow instructions, if you are able to format successfully, then no worries if formatting is not done.....
ii) then try to keep your windows'xp or vista cd in the cd tray and restrat system and follow the procedure formating system(i'm not saying to install or reloading a pc), when u reach a position where u see all the partition(like c, d ,e drive ... with memories), u will also see the flash drive partition along with hard-disk partion separately...
now click on the flash drive partition and press the button D to delete partition and follow instruction after do this , press C to create partition and u will see that a letter(e, f..) will be given to our flash drive....
now quit xp (by pressing ESC, donot proceed loading XP or vista) and now restart system and i think ur flash drive will work.....
Dec 30, 2008 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Formatting errors on 2 memory cards - old 1gb & new 4gb micro sd sandisk
http://www.sdcard.org/consumers/formatter/eula/
Go here follow the instructions to get a formatter program
May 16, 2008 | SanDisk 2GB microSD Memory Card
Toshiba 2GB USB Flash Drive Capacity Problem
format the Flash Drive in in slow mode
click on the properties of flash drive
then click on tools then CLICK ON DEFRAGMENT NOW TAB
Mar 11, 2008 | Computers & Internet
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
356 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
