Question about Samsung Televison & Video
Why is my tv whistling? - Samsung Televison & Video
JVC TV issue. A componant from the power suplpy board is whistling
This tv problems is a very easy thing to fixed.Take the tv aparts.The FBT-(Flyback transformer) the big block of plastic with a red wire with a cap hook to the tv CRT-(tv tube).At FBT that body of that big block of plastic there is a 3" of steel rod like a paper clip on that big black block of plastic have high voltage current gap.That the whistling noises came from.Get some Supper Glue and put it on that 3" of that rod of steel look like a paper clip and help to seal that gap.The whistling noises will stop for good.
Aug 18, 2011 | JVC Televison & Video
Whistling sound
This tv whistling sound are causes by a high voltage currents flow from it is tv power supply board it self not functions properly anymore.That the board where the power a/c cord plug into it.Those high voltages tranformers have gaps in it solders joints and now it not letting high voltages currents flow smoothly anymore,that where the whistling sound came from.Tries take the tv aparts,tries to put some kind harden or supper glues to all those high voltages tranformers,might help or soften the whistling sound alot.If that did not help all or alot.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 28, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My TV, HITRON CS 6404SV gives a mild whistling noise when switched on.
The mild whistling noise is usually caused by a fault in the HV circuit of the tv. My money would be on the flyback transformer. Since this is un-doubtedly the most dangerous repair that can be performed on a CRT tv, I strongly suggest that you seek the assistance of a qualified tv tech. I am talking about a part that generates 25000V.
Dec 05, 2010 | Samsung Televison & Video
Power light not on, no sceen on , whistling sound coming from tv
The whistling is caused by the power source that is overstressed by a short - a big part inside it has failed. The tv must be opened and the parts tested by a pro. Call one, there's nothing else you can do.
Sep 07, 2010 | Philips 32PW6006 32" TV
LG HD Flat screen TV whistles
Ur power supply board is where the whistle came from.
Open the back cover,take a screw driver back handle taps all the transformers, so all the gaps pockets in the transformers clear up.The whistles will stop.
Dec 13, 2009 | LG 32LG30 32 in. LCD HDTV
High pitched whistling
Try changing refresh frequency, color depth or resolution (wait for the whistle to appear before testing). Admittedly, you might have to give up some image quality - less colors, or less resolution. There is probably a problem in the TV syncing mechanism - if you can, try getting it replaced. "High pitched whistles" in video and TV hardware are usually harbingers of bad news.
Aug 24, 2009 | Samsung SyncMaster 245T 24 inch LCD...
Loud whistling noise coming from tv speakers
a couple of things could make the tv chassis whistle
1 coud be dry solder joint probably on power capacitors
2 IF your tv has tube the board on the back could be making the noise its to do with the yoke on the way out!
Jul 13, 2009 | Televison & Video
28 inch
Have a look around the TV and see if you have any recording equipment there if there is move it that will stop the whistling.
Dec 29, 2007 | Durabrand DU1901 TV
Televison & Video Logo
81 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
