Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
I can't open the case so I can't change the batteries. how do i open the case?
  • 99 Answers
Pull the front cover of the thermostat straight off the base.
Pull the front cover of the remote sensor straight off the base.
Posted on Oct 08, 2009
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
How to open case and change cmos battery on cs5111 also what type of battery
Not hard Ed if you look on the back of the case Most of the time the left side if you are looking from the front will have two thumb screws one top and one bottom. Pull those off then slide the cover off. The cmos battery will look like a big watch battery just pop it out and hit walmart or any drug store that sells watch battery's should not be to had to find
Dec 13, 2013 | ASUS Computers & Internet
Replace cmos battery and case openning
Asus motherboards usually use a lithium CR2032 battery for CMOS. Also, on the top of the old CMOS battery you took out there should be the exact battery type engraved on the surface.
Batteries Plus in Wichita, KS has a good online store for purchasing your replacement battery.
Dec 12, 2013 | ASUS CS5111-AP007
How to open bluetooth headset motorola H730 to change the battery
Jorge
The battery is not replaceable by consumerrs. Mark
Motorola Support
Sep 24, 2012 | Motorola Mobility H730 Bluetooth Headset
Need to change battery
Open the casing with a flathead screwdriver by orying open at the slot in the side. Completely remove the circuit board from both halves of the casing to access the battery.
Jun 13, 2010 | Genie Company IntelliCode GICT390-1BL...
How to do you open the case to change the battery?
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Mar 02, 2010 | Al Agnew Al Ag 3 Piece Pocket Watch...
Car door opener not working..where is the battery? Is there one?
The remote does have a battery. It either has a small door that slides open or you remove a screw to separate the two halves of the case. The battery is inside.
Sep 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
How do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
144 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Heatmeister99
Level 1 Expert
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
