Question about Asrock 845GV (P4I45GV) Motherboard
Mother Board Fan Making too Much Noise
Hey How r u I am one As rock mother board and in that CPU fan is making too much noise kindly guide me what to do in this case.
  • irfan_sm Jul 23, 2008
    cpu fan is making hell lot of noise. I even changed the fan. Its actually making fan to run much faster. Is there a way to slow it down?
    Problem Solver:
  • 8 Answers
There are 2 main reasons for the CPU fan to run noisily.One is that there is film of dust accumalated on the cooling fins thus not allowing air to circulate and cool the CPU properly.The second is that perhaps the fan needs to be oiled because the sleeve bearing has gone dry.The most common problem for a noisy CPU fan is accumalation of dust.You will have to remove the fan and clean it thoroughly with a soft brush.
Posted on Aug 21, 2008
Dear Rhod
How an hardware can make a noise kindly let me know in detail how to check hardware.
Posted on Dec 22, 2007
Check the fan or maybe its your harddrive makin noise
Posted on Dec 21, 2007
Ge gsh25jfrf bb sise by side refrigerator. Freezer not cold, fan not running, not turning, and is making a clicking sound. What's the cause of this?
if the fan is making a clicking noise, replace it, but be prepaired to replace the main pcb if it does not start right up..... on a ge if the evap fan motor shorts it will take out the mother board (pcb)
Oct 09, 2014 | Refrigerators
I can't get my CPU fan to connect to my mother board because the plastic clips are broken what can a do
What is the make and model of the motherboard and what is the make and model of the fan?
Mar 29, 2013 | Computers & Internet
Cpu fan is making much noise even i changed it.
First open your cup and clean the fan with vaccume cleaner.
and check the cpu fan speed if required change the cpu fan.
May 19, 2010 | Asrock 845GV (P4I45GV) Motherboard
The HP dv6700 has a noisy fan but the noise
Apr 15, 2010 | HP Pavilion DV6700T Notebook PC
My hp pavillion dv000 wont trun on, when i press p[ower buttin , lights comes on, no fan noise, dvd drive make litlle noise, green light on and off, after20 seconds alllights trun off, please help
mother board repair or replace disc check and bios is still coming up but the part that kicks on fans for cpu isnt working hope fully it didnt damage cpu but its possible
Nov 07, 2009 | HP Computers & Internet
Noisy system fan
Here are a couple things to check.
  1. Are there other fans (other than the one you replaced) in the system? Many times, even with systems that use one main fan to cool the CPU and case, there can still be a fan within the power supply. There's a good chance that the power supply fan is the noisemaker. Also check for a fan on the video card.
  2. Check to make sure there are no wires or debris that could be lying against the fan blades.
My guess is #1 is the culprit.
Mar 16, 2009 | Dell Dimension E521 PC Desktop
My cooling fan on my mother board start making noise now as soon as you power up the pc it shuts down could it over heat that quickly or did it ruin mother board?
It is possible to burn out a processor in a matter of seconds without cooling. Please do not attempt to restart the unit, until you replace the colling fan on the processor. If it's not the processor fan/heatsink, you may have lucked out, but don't restart it till you replace the fans.The fan that sits on your cpu is the main concern, if it's one of the others the board should shut down automatically in order to stop this scenario from occuring.
Mar 09, 2009 | Computers & Internet
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Nov 10, 2007 | Hotpoint HSS25GFP Side by Side...
Cpu fan noise problem
You should check and make sure the inside of your computer isn't dusty. Dust will wreak havok on fans and shorten their life. Plus it likes to build up between the fan and heatsink which will overheat your processor. Take the fan off and spin it with your fingers. I like to open the little sticker on the bottom and put some 3 in 1 oil to lubricate it. A smooth spinning fan is a happy computer. It also reduces noise that a dirty fan makes. Hope this helps you.
Sep 16, 2007 | Intel D915GAG Socket 775 Motherboard -...
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Asrock 845GV (P4I45GV) Motherboard Logo
684 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
