Question about Krups KM4065 12-Cup Coffee Maker
I bought a Krups coffee maker KM4065 less than a month ago and suddenly it will no longer percolate/brew. I have not changed any portion to how I prepare/program/clean the machine. The warming plate will heat up and it will make the sound as though it is going to start to percolate but then stops and quiets - the machine stays on the whole time. When I open the top, I can see that a very small amount of water has reached the filter but that is it.
Under warranty and will have to ship to service center or eat the cost - no further assist needed
Posted on Oct 03, 2009
Where can I get a thermal fuse harness for a Krups mk7000
If it is no longer available why not read the temperature rating on your dead fuse and replace the fuse only?
Aug 18, 2014 | Krups KM7000 10 cup Grind and Brew coffee...
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Krups km406 will not brew coffee
could be clogged pump or bad pump, I have also seen where you need to let the water reach a certain temp. before it will begin to brew
Jul 14, 2012 | Krups KM4065 12-Cup Coffee Maker
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
Coffee maker brews MUCH slower and makes less coffee
It may not help but won't hurt; put a couple of cups of plain vinegar into the water chamber, turn on briefly until it starts to pump, then turn off and leave overnight - at least, if not longer. The mild acid content may clear some lime buildup.
Apr 14, 2010 | Cuisinart DCC-1200 Coffee Maker
Hi, I have a Miele 4070 that I... Answer Hi, I have a Miele 4070 that I bought 3 months ago. It made great coffee for the first two months... (More) Hi, I have a Miele 4070 that I bought 3 months ago. It...
d-hound same problem spoke to tech re 4070 they say it is just gring amount and beans and grind they are wrong made great coffee 30 days now **** water please call Randy 484-695-2450 or rppt@aol.com
Jan 05, 2010 | Coffee Makers & Espresso Machines
Coffee too weak
Probably a bad thermal switch. My wife had the same problem with hers and I recently fixed it.
What is the temperature of the coffee when if finishes brewing? It should be around 190 degrees F. If it is cooler than that it indicates the switch is turning the heater down too soon. This means the pot doesn't circulate hot enough water through the grounds and the coffee ends up weak.
Replacement switches are available from
http://www.goodmans.net although the one I got wasn't an exact fit I made it work.
Dec 05, 2009 | Toastmaster Farberware Percolator
Krups KM4065 12-Cup Coffee Maker Logo
292 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
