Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
Analog will not sync with digital
Tried to do what manuel says but will not move analog hands. Signal is strong on digital.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
I just bought a 4756. Hard to follow that manual.
In the end I used these parts of the manual
Step 1 was to set the correct time zone (off PT or pacific time to ET eastern Time.)
Step 2 was to do a manual receive of the radio time.
Step 3 was to Home all the analog hands so they all pointed to 12. see manual
Step 4 then I hit B button - top right by the 2 and everything spun around to the right time received from the manual received time.
Posted on Feb 11, 2008
2 Suggested Answers
SOURCE: analog will not sync with digital
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
Regards,
Tahir Khan
Posted on Jan 25, 2011
I HAVE REPLACED TWO BATTREIS BUT ANALOG TIME IS NOT WOKING WHAT TO DO?
try to reset the clock and if it still doesn't work I think its broken.
Feb 27, 2017 | Watches
Waveceptor 4379. Why aren't analog and digital displays synchronized?
If the analog part has been exposed to a magnetic field or very strong shock the hands may move some steps on. There should be a way to calibrate the analog part to its initial 12 o'clock position, from where the analog part will just catch up with the digital part.
Aug 29, 2015 | Casio Watches
I cant fix the analog of my watch pasnew model PLG_1002AD GRADE A QC 6
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
Mar 06, 2015 | Watches
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
How do I set the digital time on a Casio G-Shock AWG-101
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please
Mar 15, 2010 | Casio Watches
Day and date out of sync with time
Try rotating the analogue hand 12 hours ahead of the current time
Jun 19, 2009 | Caravell Bulova Caravelle watch
Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Jun 20, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Regards,
Tahir Khan
Feb 14, 2008 | Watches
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
593 people viewed this question
Top Casio Watches Experts
Ansel Alberto
Ansel Alberto
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
