Question about HP Photosmart C3180 All-In-One InkJet Printer
Check print Cartridge lights are flashing. I have changed both and still have the same error. I have unplugged resarted but still have the problem
    Scholar:
  • 53 Answers
Posted on Oct 03, 2009
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Z1380 green power light flashing constantly. Cartridges not returning to right hand side of printer. No printing possible.
The flashing light on your printer could indicate either a paper jam or a cartridge problem. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While cover is open, check for any obstructions in the cartridge carrier's path. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, insert one cartridge first. Close the cover and check for any errors. If none, re-insert your other cartridge. Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the other is faulty. If cartridges are fine, load some paper (avoid overloading). Also, use the specified paper types and sizes for your model. Try to print again.
Jun 23, 2011 | Lexmark Z816 InkJet Printer
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Are you using a factory new ink cartridge?
    If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
    If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
    Don
    Nov 10, 2009 | HP Photosmart C3180 All-In-One InkJet...
    Error 1203
    hi..
    error 1203 means either or both cartridges have short circuited and needs replacement..
    You will need to perform the following steps to find out which cartridge is defective:
    1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
    2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
    3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
    1. Make sure the printer is in “Copy Mode.”
    2. Press the “Menu” button once.
    3. The screen will display “Copy Menu: Copies”.
    4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
    5. Press the check button once. The screen with read “Tools: Maintenance”.
    6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
    7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
    8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
    If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
    1. Turn the power OFF.
    2. Open the front cover.
    3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
    4. Reseat both cartridges in the printer and check for the error.
    5. If the error still displays, then remove the color print cartridge.
    6. Close the cover.
    7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
    8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
    9. Remove the black print cartridge and reinsert the color cartridge.
    10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
    11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
    Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Hp lj 2500 flashing yellow light
    The yellow-print-cartridge
    light is blinking, and the
    printer stops printing.
    empty or missing.
     The printer cannot
    detect the print
    cartridge correctly.
    1. Reinsert or replace the print cartridge.
    2. If the print-cartridge light is still blinking but the
    Attention light is not on, turn the printer off and
    then back on.
    3. If the problem persists, repeat the above steps
    with yellow print cartridges until the error is
    resolved.
    4. If the problem persists, replace the printcartridge
    E-label reader, which is located on the
    pressure assembly of the print-cartridge
    carousel.
    Jan 09, 2009 | HP LaserJet 2500L Printer
    Flashing light check print cartridge
    You must replace all ink carts with new ones at the same time. Yeah, this how HP makes its money.
    Jan 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
    Not printing green light flashing red one constant
    Here is the indicator light error page from the Service Manual
    You will see there is no specific error of "Power flashing" with "Error On". The inference is that the Power light was doing someting to cause it to flash (e.g. jn cartridge change mode) when something went wrong to cause the "power no change" with "red light on" error. The most likely I think is "no cartridge" - or more likely "faulty cartridge looking like no cartridge". Have you tried re-replacing the cartridge with yet another. Other possibilities are some sort of mechanical jam. Please report back on this.
    Dec 17, 2008 | Epson Stylus 680 InkJet Color Printer
    Frozen flashing multiple errors
    pull ur ink cartride from cas and clean it and put it again
    May 01, 2008 | HP PSC 1510 All-In-One InkJet Printer
    HP Photosmart C3180 All-In-One InkJet Printer Logo
    303 people viewed this question
    Seeker5211
    Seeker5211
