Question about GE GSS25SGMBS Side by Side Refrigerator
GE model #GSS25WGPE BB Freezer coils freezing and making fridge warm. I have defrosted it twice and it keeps freezing over and making the fridge too warm for food. Is it the Defrost timer, heater, or thermostat?
  • senittman May 11, 2010
    there is a main board on the back of the fridge....the self defrost runs off of a relay on that board and that is a very common problem with those going bad on GE's...i'm almost positive that is going to be your problem...part number is WR55X10037...price is around $150
catriver
  • 878 Answers
SOURCE: Fridge not working
Speed, If your model number begins with 596. This is made by Amana with the Kenmore name. Look at your defrost thermostat that sits on the evaporator, see if its bulged. If it is it's more than likley your problem. Part number 12001937. Your heaters should be calrod and seldom fail. Advance the refer into defrost by turing the mechanical timer clockwise until you hear it click and see if the heater comes on. Should find the timer under the control panel, should be a slot you can use a screw driver to turn it. If the heaters don't come on you can temp. by pass the bi-metal by simply cutting it out,connecting the wires and putting it into defrost again. However, it must be replaced. This is a safety device. If the heater now comes on, it's your bi-metal. If they don't come on with the bi-metal by passed, check for 120V at the heater connection. If no voltage, its your defrost timer. Careful in there your working with live voltage...Catriver post back.
Posted on Sep 07, 2006
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
SOURCE: evaporator coil freezing over
You are probably correct, the auto defrost sub-system is faulty -- and probably the timer. You'll have to take the back panel out of the freezer to see the defrost timer.
Posted on Apr 29, 2009
The fridge is not getting cold, just maintaining a luke warm temp. The freezer is working fine. I decluttered both of them to try to help the situation..No matter what temp I put the fridge on, it doesn't...
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Sep 20, 2009 | GE Refrigerators
Our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Jul 13, 2009 | Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My freezer coil keeps freezing up. I replaced the
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Apr 29, 2009 | Kenmore Refrigerators
Apr 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Model PDS22MBRABB bottom mount
These fridges were made by LG they are very problematic, the defrost cysle does not work properly due to board defects and the fridge freezes up, I have replaced my board twice and the fridge has worked properly for 6 months max them the board shorts again, I talked with the LG rep he said scrap the fridge they are ****.
Nov 06, 2007 | GE Energy Star PDS22SIS Stainless Steel...
Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
247 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
