Question about Refrigerators
Samsung RS 2555 SL is the model number of my refrigerator. It stopped cooling. The temperature display on the is now flashing. How do I fix it? Does it look like I have to call a technician or I just need to do some resetting or change fuses.
SOURCE: i HAVE A SAMSUNG RB2055SL REFRIGERATOR AND IS NOT COOLING RIGHT AFTER A WHILE THE TEMPERATURE STAR BLINKING
i have the same problem. did you figure it out
Posted on Jan 15, 2008
SOURCE: samsung refrigerator rs 2534ww
Samsung freezer.
The freezer temp will not go back to the temp it was originally it keeps dropping back 15 degrees below to what i set it.
Posted on Nov 18, 2008
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Posted on Jun 21, 2009
rickead1
  • 1998 Answers
SOURCE: samsung refrigerator RS264absh Freezer not cooling
I would check three things in your freezer seeing how your getting ice the t-stat ,the heater,and the fan these are the first things you check with ice build in freezer your freezer is what actually produces the cold the air from the freezer travels through small vents into your refrigerator sounds like a definite defrost probelm in your freezer
Posted on Apr 29, 2010
SOURCE: My Samsung Refrigerator can not keep the set temperature.
DO NOT BUY ANOTHER SAMSUNG PRODUCT _ BOYCOTT
Posted on Jul 08, 2010
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
How to fix the rs 2555 refrigerator is not cooling, but the freezer is fine
1) Twin Cooling System
┬ĚThe refrigerator and the freezer have two
evaporators.
Given this independent system, the
freezer and the refrigerator are cooled individually as
required and are, therefore, more efficient. Food
odor from the refrigerator does not affect food in the
freezer due to separate air flow circulation.
The Evaporator unit for the fridge may need servicing.
if you handy with tools you can fix it yourself the manual link is below
http://vdmeulen.net/handleiding/Samsung%20SR-S24%20FTBS/samsung%20rs2555sl%20service%20manual.pdf
Aug 16, 2014 | Refrigerators
Can you tell me what a flashing # 4 means on the fresh food display,when I try to set temp.the flashing # 4 keeps coming back. the fridge temp. is too cold and freezes everything.
Hello Bryce,
I found a manual, although I cannot be sure it is for your exact model, it is located HERE. This is what is stated under "Temperature Adjustment"
IF TEMPERATURE DISPLAYS FLASH... If ever you see both temperature displays continously flashing, it may indicate that the control system has detected a performance problem. Call your service representative, who can interpret the flashing message. To maintain temperatures, a fan circulates air in the refrigerator and freezer compartments. For good circulation, do not block cold air vents with food items.
This is located under "Turning the Cooling System On and Off"
TURNING THE COOLING SYSTEM ON AND OFF You can disable the cooling system in your refrigerator by pressing the On/Off button located on the left side of the temperature control panel. To ensure that you do not accidentally turn off the cooling system, the button does not work unless you press and hold it for three seconds. Once you disable the cooling system, all refrigeration to the freezer and fresh food compartments stops. To turn the cooling system back on, you must again press and hold the On/Off button for three more seconds.
If the manual I selected is not the one for your particular machine, there are others located HERE. There are various ones only differing by a "upgrade" letter on the end, perhaps for different models of different manufacturers, produced by the same company.
I hope this is of some help
Joe
Sep 20, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a new Samsung side-by-side refrigerator (model # RS265TDRS) that I am using for the first time. I plugged it in today, and the control panel display has been flashing "23 E" all day (NO...
Push and hold power freeze and power cool simultaneously until display flashes. Release and leave alone. You just reset the brain on your display. In an hour or so, reset the desired freezer and refrigerator temps. My suggestion, -6 on freezer, 44 on refrigerator.
May 16, 2017 | Samsung RS265LBBP Side by Side...
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My samsung ref rs2555sl stopped cooling. The temperature display for both freezer and fridge on the front keeps flashing. What do I need to do?
Most of the time if you unplug it from the power source for about 10-15 minutes will reset fridge computer and when you plug it back everything get back to normal.
Oct 02, 2009 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
358 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
