Question about Apex Digital GB51HD09 51" Rear Projection Television
Apex GB51HD09 will not turn on
I hit the on button, light flashes 4 times and then nothing. It turns on some days for 15 minutes and then off for a few more days. Somedays it turns on for a few hours then nothing.
    Problem Solver:
  • 18 Answers
On the power board you will find 4- 35Volt X 1000mfd radial lead capacitors on the right rear corner of the board all in a row from right to left, the 2 outside capacitors have gone high ESR. This is a common problem with this model.
Posted on Dec 27, 2007
    President:
  • 4,402 Answers
Try looking in the troubleshooting section of the operating manual (usually near the back) to see if that tells you about flashing 4 times
Sounds like a loose connection or a part that heats up, sometimes you can get a can of freeze (radio shack) and spay on the part if the part is over heating to see if you can get it to stay up longer.
Posted on Dec 21, 2007
My TV was taking forever to turn on
YES SIREEE, THE BULDGING CAPACITORS ARE MOST LIKELY YOUR PROBLEM. DO YOU KNOW HOW TO CHANGE THEM OUT??? IF YOU DO, I WOULD SUGGEST REPLACING THEM WITH NICHICON OR PANASONIC CAPACITORS.
May 10, 2012 | Vizio VW26L 26 in. LCD TV
Chance time in cherokee 2005 with navigasion is no time botton
If you have a VIC (Vehicle Information Control), hold the set button down until the hours start flashing. Once the hours are flashing, hit the set button to change the hours until you've got the hours correct. Then hit the Select button and the minutes will start to flash. Hit the Set button until your minutes are correct and then hit the Select button again whereby the AM/PM button will flash, hit the Set button until your time's correct, then hit select to move to the day, date and year and when you're finally done, (after all the hitting of the SET & Select buttons, just hit the Select button and nothing will flash and your time is set. Should you have a radio that displays the time, push down and hold the TIME button until the hours begin to flash (with the radio turned off), then turn the volume wheel until the correct hour is displayed. To adjust the minutes, turn the Tuning knob until the minutes are correct. Once you're done, don't touch any of the buttons and the clock will display the correct time on it's own...when you've released all the buttons and dials.
"00 Buck"
Nov 06, 2009 | 2005 Jeep Grand Cherokee
Apex GB51HD09 convergence
Please have it taken care of ASAP. It definitely sounds like Cold Solder joints on the convergence IC's. Cheap repair now, if you stop playing it. Every-time the convergence goes out, the ic's struggle to bring it back in and can't and therefor over heat. so please have it taken care of Pronto. Apex used a Samsung chassis which was a good chassis in that PTV.
Aug 19, 2009 | Apex Digital GB51HD09 51" Rear Projection...
Service menu
The volume on my tv just stopped working.
Apr 15, 2009 | Apex Digital GB51HD09 51" Rear Projection...
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Door locked, start pause light flashing
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Jun 11, 2008 | GE WSXH208A Front Load Washer
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 | Watches
Apex G51HD09
you can try and see if ptscorp.com will repair the board.
Jan 09, 2008 | Apex Digital GB51HD09 51" Rear Projection...
Apex Digital GB51HD09 51" 2002 model situation
Dec 15, 2007 | Apex Digital GB51HD09 51" Rear Projection...
Mind of it's own
contact ptscorp for repair of the board.
or DIY
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2006 | Apex Digital GB51HD09 51" Rear Projection...
Apex Digital GB51HD09 51" Rear Projection Television Logo
195 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
