Question about Toshiba 65HX83 65" Rear Projection HDTV-Ready Television
I have a 65 inch Toshiba projection TV.. we have add it for about 6-7 yrs and the focus is starting to fade. If i put it on the HD station for about 10 min the focus comes back in and all channels are clear.. It seems like something is going or a focus needs to be re adjusted..please help
techman
  • 3130 Answers
SOURCE: Toshiba 65 inch projection TV
Yep, sure sounds like a tuner pproblem my friend. good diagnosis! If you have any soldering experience and know how to work on solid state circuit boards, then you should have no problem replaceing the tuner for this set. Now it could also be a problem with the HYPER PCB assy. This is what controls the tuner and some sets the tuners on the hyper board. the complete HYPER board is avail. at http://www.partstore.com for about 165.00 + shipping. You can also check with http://ptscorp.com for a rebuilt hyper board assy. If you have no experience with TV repair PLEASE stay safe and call in a trained servicer to assist you with this problem. Good Luck
Posted on Nov 12, 2006
  • 150 Answers
SOURCE: Toshiba 65"HD rear projection tv
is the light flashing? Many things will cause a no power condition, might be shorted Convergence IC's, Z801 Ic could cause trouble, might want to call service man.
Posted on Jul 06, 2007
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
SOURCE: blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Posted on Sep 06, 2008
  • 3 Answers
SOURCE: wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
It's the hyper mod board. I've replaced many of these.
Posted on Oct 09, 2008
Changed 6 lamps y65 none work can they all be bad
Sounds like the circuit that is responsible for sparking and maintaining the voltage to the lamp has gone bad. It's called the Lamp Driver.
Don't waste any more money on lamps. Get a tech to have a look at either repairing or replacing the lamp driver.
Sep 13, 2014 | Toshiba Televison & Video
I have a 65 inch toshiba cinema series it's says
if a large rear projection set that just says HD, it likely is HD ready which means it needs a set top box connected to the Colorstream input marked 1080 on the rear of the set--It will only likely be 1080i and not p---owner manual would confirm this.
May 28, 2012 | Toshiba Televison & Video
Brightness is fading. Unable to watch a DVD or USB camera the picture is unviewable. Watching TV is not clear anymore
hi,
i think ur tvs crt base have some problem. from ur explanation it may be because of the focus is out. just replace the crt base for the three guns (at the same time). then try again.
ok
Dec 22, 2010 | Toshiba 65HDX82 65" Rear Projection...
Images fading fast. Cannot read text on screen. Could hardly focus on images. Need to obtain part: Screen Focus Block
The lens is getting clogged. All u need if u have little expertise open up the TV.
and clear the lens or projection hd there with a soft clean cotton cloth
May 29, 2009 | Hitachi 51F59 51" HDTV Projection...
65 hd projection tv -no picture-red power light is flashing-help
There are many circuit failures that can cause the TV to do this. By far the most common issue is a failure of the convergence output ICs. Expect to spend $350-450 to fix this.
michtech
Feb 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
65 inch Mitsubitshi hd dlp
The tv has a bad lite engine. Please call the manufacture's customer service and asked them for a concession for this repair. This a $700.00 to $900.00 repair. If you persist 95% of the time they will cover this repair for you. Use the word 'concession' that's there verbiage.Good luck.
Apr 03, 2008 | Mitsubishi WS-65513 65" Rear Projection...
60" RCA PROJECTION TV
my tv is 12 yrs old it started with the color starting to fade and then it started cracklin real bad and now theres no pic but there is sound
Dec 29, 2007 | RCA P60921 60" Rear Projection Television
Toshiba 65HX83 65" Rear Projection HDTV-Ready Television Logo
507 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
