Question about Phoenix Gold Octane-R 8.0:4 Car Audio Amplifier
My amp is in protect mode and i was wonderin how 2 get it out
    President:
  • Phoenix Gold Master
  • 1,114 Answers
The quickest way to determine if the problem is in the amp, the wiring, or the speaker(s) is to disconnect all speakers at the amp and re-power. If it stays in protection, check your ground. If you are grounded to a seat bolt or side panel on the vehicle, move it to the floor. Scuff the surface, check underneath for wiring or fuel lines! and drill a new ground. If it's still in protection, meter the voltage at the amp, if it's lower than 9.6v, that's your problem. If it's 11-13v and still in protection, the problem is internal and the amp needs service. If the amp leaves the protection mode when you disconnect speaker(s), check speaker wire for loose/touching wires or cuts in the shield. If that's ok, meter the speaker for resistance. If your meter reads 1..... the voice coil is burnt. If it reads .....1 the spider or coil is open or cut and again is bad. If you don't have a meter, any car audio shop can test your spkr(s) in just a few minutes. If you need further help, post a comment and I can help you more.
Posted on Oct 03, 2009
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Nad C350 2 channel Amp continually in protection mode
That could indeed be the issue, but you must check your speakers, wiring, and also the oupt stages for problems. Maybe the prtection circuits are actually doing their job. lol
Hope that helps...
Geno
Apr 02, 2008 | Audio Players & Recorders
What does my protection light come on after hooking everything up
There is something shorting out the amp. What you will need to do is disconect all wires and hook up one at a time. Connect ground, !2 volt and remote see if amp turns on ok. If it does try connecting each speaker seperately to see if either one sends the amp into protect mode. Then connect the rca. See what causes the amp to go into protect mode.
May 08, 2013 | Car Audio & Video
My amp is protecting unessacarily when ran at 2 ohms
are you factoring the ohm rating from running them parallel?
2 x 2o subs parallel = 0.5 ohm (lowers ohm's)
2x 2oh subs series = 4 ohm
IT is posable that you are calculating the ohm rating fine, BUT some SUBS can reach lower ohm rating while hitting bass- i didnt know this till i had a rather insane sub that would dip to 1ohm while hitting hard bass causing my amp to go into protect mode.
May 21, 2009 | Rockford Fosgate T10001 bd Car Audio...
Power light turns from green to red protect mode and then there is no sound coming from my speakers
there are 2 reasons for it to be going into protect mode 1 is heat 2 is the load on it. if it is going into protect mode soon after it starts there is a problem with the speaker. if it is after it has been on for a while it is that the amp itself is overheating. hope this answers your question
Apr 27, 2009 | SPL Audio Phantom DK2-1000 Car Amp
Amp problem
Some amps very in what will happen first, some will blow the fuse and some may go in protection mode or the sound will come and go.
Dec 06, 2008 | Car Audio & Video
Amp is in protect mode, green light is on.
If the amp is going into protect, it likely has shorted output transistors. To eliminate other possible causes, read through the following page.
Amp in protect mode - troubleshooting
Let me know if you have any other questions.
Nov 29, 2008 | Phase Linear UPA424CS Car Audio Amplifier
Red status Light
If the protection LED is lit, the amp is in protect mode and probably has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Trubleshooting
Nov 07, 2008 | Boss AUDIO RIP-596 2-Channel Ripper Series...
Amp going into protect mode
If you set the gain too high on the AMP, at loud volume levels some clipping or distortion of the output signal will occur. Most amps have a Circuit inside that detects this clipping or distortion and applies protection to prevent damage to the speakers and the amp. It would help to know if you are driving the speakers with a Line level output or using the speaker output from your deck. There are many things that can cause an amp to go into protect mode, and knowing a little more about your setup will help to solve the problem.
Nov 07, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Prower acustic amp in protect mode
1) Make sure the amp is properly connected to +12V power source. 2) Make sure the amp is grounded well, directly to metal - if you have a voltmeter, an easy way to check the first two is to see if there are 12 volts across the power and ground wires. 3) Make sure the speaker output wires aren't touching each other. If none of these are the case, there is an internal problem with the amp and it should be serviced or replaced.
Sep 18, 2007 | Car Audio & Video
Phoenix Gold Octane-R 8.0:4 Car Audio Amplifier Logo
226 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Matthew Spark
Matthew Spark
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
