Question about Kenmore 17252 Free-standing Dishwasher
My dishes are not clean after the diswasher cycle.
  • 71 Answers
Make sure the spray arm holes are clear of debris...all of them.....if they are then there is usually something in the screen down at the pump(like plastic or glass) just make sure everything is clear of debris and that should take care of it.
Posted on Oct 03, 2009
After running a full cycle the dishes have a film left on them. Sometimes soap is not rinsred off the dishes. Tried different soaps for dish washers. It seems the only thing to take the film off of the...
Film on dishes post cycle is caused by 2 things.... Poor water flow during the wash / rinse cycle.... i.e clogged sump inlets or restricted drains. Clean the drain hose first. Start at the cink connection and clean EVERY connection and in-line componenet from the port hole at the sink connection all the way back to the drain hise connection port at the dishwasher.
If you still have dirty dishes post cycle after drain cleaning... then remove the lower wash arm support and clean the accumulator / sump area thoroughly. See this link: (items 1 and 4) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140844&diagram_id=28222738#d28222738
Test again.
If the problem persists you will have to gain access to the pump impeller. Inspect the impeller, and pump housing for damage. UNDER the dishwasher. Item 22 of the above link.
This should get your diswasher performing properly again.
I used this model number as a reference: GU2400XTPB1
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Our integrated dishwasher takes on water but the tablet does not disolve. The dishes are not clean after the cycle but they are hot.The water empties.
Buy a Finish diswasher cleaning kit from the supermarket and run the dishwasher with it. Follow the instructions on the label of the kit. Use one of the long wash cycles on the dishwasher so that temperature reaches above 60deg C.
Also provide the make and model number of the dishwasher.
Dec 10, 2010 | Dishwashers
Diswasher used to get dishes clean. now there are spots, film and food remnants on dishes after cycle completed. The dishes look awful
Check taht the detergent is getting dispensed and the water is hot and you can hear the water spraying.
ALSO refill the dispenser for the liquid sheeting such as JetDry. That is usually in the door with a twist out plug. It usually lasts 6 months or so.depending on the use.
Sep 14, 2010 | Dishwashers
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Dishes still dirty after wash cycle
It would be real helpful to have you provide the manufacterer and model number to get more specific with solution.
-Have you changes dishwasher soap powder recently? Buy a box of Electrosol or Cascade and see what happens. The ultracheep versions actually have caused cleaning problems, especilly in water-conserving dishwashers.
-Under the lower rack is the sump area with a filter that can be removed, usaully by removing several screws. Pull that filter, rinse is as best you can. Inspect under where the filter was and remove all debris. Watch out for broken glass that is found in most well used diswashers, it is hard to see and sharp! Reasemble the filter.
-If problems continue and if this diswasher is several years old, plan on getting the wash pump motor replaced (or replace the diswasher with a name brand, Energy Star model.) Good Luck!
Please update me with what you found. OK?
Mar 30, 2009 | Dishwashers
Diswasher detergent door
lizzie1 First thing check if the lower dish rack is in right position. If it is in wrong position it is not enough room for the lid to pop up open. Try to turn the dish rack around and see if it works. If not, then I'll need the full model number for your dish easher. Gendos...post back
Jan 28, 2007 | Whirlpool 24 in. DU850DWG Built-in...
Kenmore 17252 Free-standing Dishwasher Logo
111 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
