Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Where can i get a motor 12dcflame generator and where can i find a circuit board-flame speed control? furthermore, does pyromaster have a parts department and what is the head office address and phone number? hef33
I got the very same number 10001978 from ibuyfireplaceparts.com with no problem and got it within a couple of days of placing my order. The sales rep said they have plenty of fireplace parts for Vermont Castings, Majestic, Napoleon, Monessen and many more. The rep I spoke with was extremely helpful and I tried about five other companies before I stumbled across them. I would recommend this store highly.
Posted on Jan 14, 2010
    Problem Solver:
  • 7 Answers
Try www.ibuyfireplacparts.com. P/N is 10001978. Cost is $77.01.
Posted on Oct 04, 2009
I got a 2000 Oldsmobile Bravda and has smart track that works when it wants to the service light comes on once and awhile. When I really need 4wd it doesn't kick in Help
There are three different transfer case's ! Which of these does your olds have ?
Transfer Case - NVG 136-NP4 (One Speed Automatic)
Transfer Case - NVG 233-NP1 (Two Speed Selectable)
Transfer Case - NVG 236 (Two Speed Automatic)
All three have an electronic control module ! When the light is on DTC'S are stored in the transfer case shift control module .
SERVICE indicator (AWD/4WD) lamp
The SERVICE indicator (AWD/4WD) lamp is an integral part of the instrument cluster and cannot be serviced separately. This lamp is used to inform the driver of the vehicle of malfunctions within the automatic transfer case (ATC) system. The SERVICE indicator (AWD/4WD) lamp is controlled by the transfer case shift control module via a Class 2 serial data message.
There are three speed sensors on the Automatic Transfer Case (ATC), two on the rear output shaft and one on the front output shaft. Each speed sensor is a Permanent Magnet (PM) generator. The PM generator produces a pulsing AC voltage. The AC voltage level and number of pulses increases as speed increases.
Vehicle Speed Sensor
One of the two speed sensors on the rear output shaft is the vehicle speed sensor (VSS). It is an input to the vehicle control module (VCM). The VCM sends this information to the transfer case shift control module via the Class 2 Serial Data bus.
Rear Propshaft Speed Sensor
The transfer case shift control module converts the pulsating AC voltage from the rear propshaft speed sensor to a Rear Propshaft Speed in RPMs to be used for calculations. The Rear Propshaft Speed can be displayed with a scan tool.
Front Propshaft Speed Sensor
The transfer case shift control module converts the pulsating AC voltage from the front propshaft speed sensor to Front Propshaft Speed in RPM to be used for calculations, and to monitor the difference between the front and rear propshaft sensor speed. It is also used in the AUTO 4WD mode of operation to determine the amount of slip and the percent of torque to apply to the front axle. The Front Propshaft Speed can be displayed with a scan tool.
Transfer Case Encoder Motor
The transfer case encoder motor is a permanent magnet D.C. motor and gear reduction assembly. The encoder motor is controlled with a Pulse Width Modulated (PWM) signal provided by the transfer case shift control module. It is located on the left hand side (drivers side) of the transfer case. When activated it turns the sector shaft of the transfer case to shift the transfer case. This circuit consists of a power supply relay (Motor Feed A circuit ) that supplies voltage to the motor. The Motor Control B circuit is a PWM driver that varies the duty cycle to control the amount of current through the motor to ground.
There are a number of codes that can set .
DTC C0300 Rear Speed Sensor Malfunction
DTC C0305 Front Speed Sensor Malfunction
DTC C0308 Motor A/B Circuit Low
DTC C0309 Motor A/B Circuit High
DTC C0310 Motor A/B Circuit Open
DTC C0315 Motor Ground Circuit Open
DTC C0374 General System Malfunction
DTC C0376 Front/Rear Shaft Speed Mismatch
DTC C0550 ECU Malfunction
DTC C0611 VIN Information Error
You don't want to just start replacing parts , that could cost $$$$$$ . You could check connections at all the sensors an the control module , but other then that ,well . Your best bet , take it to a qualified repair shop .
Feb 19, 2017 | 2000 Oldsmobile Bravada
Have a cissell 170lb dryer it will ignite than flame will go out
Most likely problem with ignitor. You can try cleaning the ignitor. One reason I can think of is that the feedback from the ignitor circuit is not working. What usually happen is that when the flame have started. The ignitor will generate a small current to tell the ignitor control board that there is a presence of flame. If the small current feedback is not detected. the system will automatically shut off the gas for safety reason. You probably tried stopping and restarting and the same condition will occur.
Jan 28, 2013 | Cissell Parts Cissell H87533014 Dryer...
I have a pyromaster hef 337b electric firelplace. The flames do not flicker at all. The motor works, we tested it. Any other suggestions? Where could we find new parts for it
If you're not getting any flame effect or only a portion of it. One or more of the 60 watt small base chandelier bulbs is burned out. Replacing one or more should solve your problem.
Apr 14, 2011 | Leisure HOMEPRIDE Electric Fireplace...
I have a Pyromaster electric fire place = model HEF33 and I need a motor 12vdc for the flame generator part number 10001978? Can I just find any 12 volt dc motor and use it ? where would I find one...
here is a picture of it. It took me about 4 minutes to put the new one in.
http://www.ibuyfireplaceparts.com/monessen/10001978-motor-variable-speed-12v-dc.html
Jul 08, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Rainbow e2 2 speed vacuum shuts off after 5 minutes of vacuuming.
2 speed E2 models have a circuit board inside that controls the machine. It sounds like this controller board may be bad. The unfortunate part of this is that the board is not only very expensive, but it is only available from an authorized Rainbow service center.
Use caution if you decide to work on this yourself or if you take it to a service center that is not famliar with these models. The circuit board mentioned above is susceptible to damage from static eclectricity discharge. The static you generate from just walking across a carpet could make this board useless. So, if the original problem is not the board you could make the problem worse.
Jan 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I have a pyromaster electric fireplace model HEF 33..my flame does not flicker ,it lights upand heats but no flame
I have the same model and problem there must be some part to get to replace it it seems to be a motor problem. would appreciate any ideas
Nov 09, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Charmglow electric fireplace flame does not flicker. Bulbs ok. HEF33WDG
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Oct 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My pyromaster electric fireplace will not turn on.Is there a reset button or a fuse to check?
Yes, there is a reset button. I have the same problem but the reset button doesn't do anything. I do have power but the flame does not come on.
Jul 01, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Pyromaster electric fire place motor for flickering flame
Any Vermont Castings stove dealer can order the parts for you.
Apr 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Flame on my electric Pyromaster is standing still is there a bulb
basically, on the bottom of the fireplace, there are 2 screws on the sides, 3 on the back, take them off, lift bottom (it wont come off, so be careful not to bend it) there are 3 christmas light type bulbs, you can find them at any hardware store. Just replace them. Problem solved.
If the flame is standing still, i assume the motor is burnt out. or the belt is off.
Nov 20, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
621 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
