Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
500GB seagate desk drive not connecting
My 500GB seagate desk drive had its USB connection knocked loose when someone tripped on it. I can hear it turning when its plugged in to power but it won't show up when the USB is connected, and it doesn't light up. Can it be saved?
  • 250 Answers
If it fell over or anything the shock probably made the drive crash, in which it's totaled. If it's under warranty, have them fix it. If it's not, you could try opening it up and you could maybe fix something that happened IF the hard drive didn't crash, and if it did you could at least use the case and put a different hard drive in there. There's a chance you might just need to solder the usb connector back on.
Posted on Oct 03, 2009
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
My seagate goflex 500gb external drive is malfunctioning
First of all check for viruses in the above mentioned folder. This problem can also be due to faulty connection between your drive and your pc, please check the cable that you r using and try a different cable.
Nov 25, 2012 | Seagate FreeAgent GoFlex Desk 500GB...
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have just purchased a Seagate 500GB Desktop hard drive
There is software preloaded on the disk. If you have AutoPlay turned off in your system, it won't start automatically when you connect the drive. Just go to MyComputer and open the drive and you will find a setup file there to install the backup software (I think it's called Launch.exe).
Oct 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Jul 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Knocked over my seagate 500 gb hard drive. makes a beep noise and will not connect to computer
you say its beeping? like an error code sequence? i would search the intnet for seagate error codes and try to match the code with the problem. or call tech support.
Jul 22, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Barracuda 7200.10 500GB Video Included. Humming, Wobbling
Brother,it is a firmware problem for seagate drives,the 7200.10 has a typical problem of firmware,once it currupt,then it cannot be detcted by the BIOS or PC ,or showing 0GB or less capacity when connected,so you can use some useful tools such as HD Doctor for Seagate to repair it,this problem is very common but less tool can deal with it till now.
Jun 28, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Connecting my Seagate 500GB USB drive reboots PC continuously.
update the firmware from seagate official,sir,any problem u can contact with me,thanks honglake@gmail.com
Nov 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
225 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
