Question about Lexmark C762 Laser Printer
I have a similar problem, recurring paper jam in a laser printer
Not sure if this is the same as you have but my printer always prints out the first page, lifts up the second sheet out of a tray, and that is it. More details, pls see http://annoyances-resolved.blogspot.com/2009/10/recurring-laser-printer-paper-jam.html
Ajkill
  • 2035 Answers
SOURCE: Lexmark E238 prints about two thirds of a page and stops
Please follow the instruction given in this link:
clear the paper jam as given in this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=37:1:0:512:0:0&framed=&docid=ENUS25568&relevance=1
Posted on Jun 01, 2008
SOURCE: Paper jam Lexmark E250d
I hate to state the obvious and I am not patronising you, but is the rear door fully closed (did it click into place) - probably. I wonder how many pages the printer has printed? If you are lucky you might be able to print out a demo page (hold the "okay" button down - the large one with the diamond/triangle on it). If it is a high number (say over 10,000 pages) then perhaps the paper pick rollers have stopped working? Also, what paper are you using? Heavy (100gsm or above) or thin (under 75 gsm) may have feed problems.
If this doesn't work you could always try printing to the rear door - this would probably stop the jam hopefully. This would enable you to print a demo page at least so you can see its page output.
Hope this helps you out.
Posted on Oct 01, 2008
SOURCE: duplex jam
repalce dupliexer or check the duplexor gears as i ahd it at one point otherwose doa printer ressetr ans ee if problem clears up
Posted on Oct 31, 2008
Ajkill
  • 2035 Answers
SOURCE: My brand new X5340 printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Posted on Dec 25, 2008
yooperbud
  • 8637 Answers
SOURCE: Lexmark E238 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
How do i adjust heat settings in xerox 6110
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
Jun 21, 2014 | Xerox Phaser 6110 Laser Printer
Error code C000 on MX860 printer. Rebooting printer allows print but problem recurs frequently
1. Open the printer's front cover, and then open and close the print head lock lever (do not remove the print head).
2. Make sure all ink tanks are seated properly.
3. Make sure all packing materials have been removed.
4. Make sure no paper is jammed in the printer.
5. Disconnect the printer cable from the printer.
6. Close the front cover and turn the printer off.
7. Unplug the printer from the power source, and then plug it back in after five minutes.
8. Power on the printer.
For more help visit cbrtechsolutions
May 27, 2011 | Canon imageCLASS MF7480 Laser Printer
Cannot clear CARRIAGE JAM on my c5180
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert technician to mend it.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Sep 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
Front paper jam
Always try to remove a paper jam without tearing the paper.
If torn, make sure no scraps of it are missing.
Lokk for any tiny scraps, esp stuck on paper path sensor.
Apr 17, 2009 | Xante Accel-a-Writer 3N Laser Printer
Problem with printing an envelope
Not an ideal solution, but, Dell printers were not desined with envelopes in mind. (I used to work there)
My solution, if you value your time at all, pick up an HP personal laser printer. Costs a little more, but the time saved will much outweigh the inital cost.
You CAN get the dell printer to work a few times maybe but consistently is not a possility....
Feb 26, 2009 | Dell 1710n Laser Printer
Printer Feeder not working well. Paper always gets stuck.
Recurring paper jams can be caused by broken parts, using too much paper in the in-tray, or parts (usually the rear door) not on all the way. This video explains how to fix a paper or carriage jam, but explains along the way the things to watch for. If you go through the steps in this video and you still get paper jammed, you may have a broken printer that needs to be replaced or repaired.
Feb 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Samsung CLP 550N paper jams
Make sure the paper guides are not too tight and always fan the paper to rid static build-up before loading.
Jan 19, 2006 | Samsung CLP-550N Laser Printer
Lexmark C762 Laser Printer Logo
212 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
