Question about Brother MFC-8840D All-In-One Laser Printer
Brother MFC 8640D paper jam issue. Some times I see no paper jam and i get error that paper jam but other times paper is stuck as soon it's picked from tray.
SOURCE: Brother MFC 7420 Paper Jam
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Posted on Jan 16, 2008
GodBlessU
  • 3513 Answers
SOURCE: I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Posted on Jan 15, 2010
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
  • 300 Answers
SOURCE: my brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
Posted on Apr 18, 2010
SOURCE: MFC-9840CDW Laser Printer: I have a Brother MFC-9840CDW laser printer it is o...
Wipe the paper feed rollers with a clean rag wetted with plain water. You can also replace the feed rollers, search for "paper feeding kit" for this printer. Should be $20 to $30.
Posted on Aug 05, 2010
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Hi, i have a Brother MFC 7620N and 8 time out of 10 when i'm printing the paper get stuck and then i get this error obviously. My problem is that the paper always get stuck,do you know any idea...
Hi!
It is due to the paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with luke-water and lint-free cloth. I hope this would fix the issue
Hope this helps! Good Luck!
CreativeTECH
May 31, 2011 | Brother Office Equipment & Supplies
Im trying to open my printer to get a paper jam out. i dont know how nto open it
The front cover with the brother logo will open. then you can pull the toner/drum assy. out and clear the jam. Steven 818-888-0006
Feb 21, 2010 | Brother MFC-8640D Printer
NO PAPER MP
Thanks
Jan 15, 2010 | Brother MFC-8640D Printer
I have a Brother mFC 8640D - paper feeds through
The black exit rollers on top get slick from the paper and toner, they need to be cleaned with a damp rag. You hold the rag against them 1 at a time and open and close the front door so they will rotate while you hold the rag on them. Should help the paper exit.
Oct 02, 2009 | Brother MFC-8640D All-In-One Laser Printer
I have a Brother 8640D all in one printer. There is a grinding noise when I go to print. The paper is going through the drum and they getting stuck before coming up and resting on the try where I pick up...
if its going through the drum, then its stopping at the fuser area.
you have a broken gear on the fuser. the fuser will need to be repaired. approx. cost for fuser repair will be about $75.00
Jun 25, 2009 | Brother MFC-8640D Printer
Clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
Brother printer mfc-8860dn
This usually means that it isn't picking up paper at all. Draw and x on the top paper and see if it takes it. You may need a new feed tire or different paper.
Apr 28, 2009 | Brother MFC-8860DN All-In-One Laser...
Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
Phantom paper jam
Same problem here. I'm googling around looking for ideas.
Sep 07, 2007 | Brother MFC-8640D Printer
Brother MFC-8840D All-In-One Laser Printer Logo
240 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
