Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Accuracy can you adjust Ct87K to be more accurate
  • 80 Answers
I believe if you take the outer ring off you will see a small resitance strip that is called the heat anticipator. You should see a small pointer that can be moved one direction or another This will adjust for your heat and cooling override.This will tell the furnace to shut off at the temperature you have it set at.
John
Posted on Oct 03, 2009
How accurate is a polygraph test?
The accuracy level of Polygraph test is about 90%. Which means it's not always reliable. It could give the satisfying result if done more efficiently and effectively if done by well-experienced examiners. Many examiners fail to detect the Lies and some professionals catch the truth because of the right Polygraph Test. So we can't say the exact accuracy level but it's accurate if done by professionals.
Click the link below to know more about Polygraph examiners and Polygraph test
Lie Detector Test in Liverpool Leading Liverpool Polygraph Services
Nov 17, 2016 | Cars & Trucks
Washer pauses then carries on during cycle - is this normal. Also cycle time is not accurate against regular house clock. Thanks.
not being advised of the make , model or if top or front loader , you ask an almost question
in top loaders when it reaches the spin cycle ,it sins and the water comes in in steps to help disperse the suds during the low speed spin cycle
as for the accuracy it is controlled by a circuit board and the timer is in the board and will not be calibrated for accuracy but if it is way out then get in a service technician to see if it can be adjusted
May 04, 2016 | Washing Machines
Accuracy after decimal?
Perhaps ten times more accurate than you can read. Lots of stopwatches go to one thousandths of a second, while the person pressing the buttons has a reaction time that can vary from one tenth to half a second. And every time the reaction time changes. So if it is not electronically is started and stopped, don't bother the accuracy of the watch.
May 08, 2014 | Casio Atomic Timekeeping Waveceptor Watch...
Where do I attach my Tag Master Pedometer with light for best results
Most pedometers need to be several inches from your center body or directly in line with your knee to accurately record the number of steps you take each day. The pedometers work by using a pendulum which moves the counter as you move forward or backward. Use the provided clip attachment to secure the pedometer to your waistband or belt. Walk for about 20 steps, stop and check the pedometer for accuracy. Adjust it closer or farther to your naval until the counter is accurate. If you have a large abdomen, secure the pedometer to the back of your waistband and recount your steps.
Sep 11, 2013 | Tag Master Pedometer with Light
How to check youself / blood pressure for accuracy i get to different reading the first time then upon checking for accuracy the second time the reading is always different
Hello Dear
All Digital equipments vary in its reading. To get the accurate reading take three readings one after the other and then the average of the reading is the accurate one.
Usually the readings varies plus minus 2 or 3 to the accurate reading.
Hope the answer will help, please rate the answer.
Best wishes
Feb 23, 2011 | Lumiscope 1080 Deluxe Auto Blood Pressure...
Have you tried working with 'Dragon Dictation'? How accurate is the transcription?
In my tests, the accuracy of the transcription has been excellent. The app even adapts to your voice over time to improve accuracy, and thus Nuance recommends that you avoid letting other people use the Dragon Dictation app on your iPhone.
Sep 12, 2010 | iPhone Apps
Is 6 seonds to fast for a breilting colt to be running
Although this is poor compared to electronic watches, I have read other makers accuracy claims and they say that a mechanical watchcan be out by as much as 20 seconds a day!
I would have thought that it could be regulated (adjusted) to run more accurately but you will have to speak to the manufacturer about this.
Jun 07, 2010 | Breitling Colt Automatic 905...
I need to adjust the focus of my Redfield widefield scope, by focusing the ret field scope does it change the accuracy of the optics?
no it dont,,, it makes it even more accurate,, how can you see clearly if its out of focuse,,,,,
Nov 17, 2009 | Optics
Accurate color
Digital cameras rely on "white balance" to control total overall color accuracy as processed for the final image. Colors are greatly affected by light. For example, look at any wall in your home or office and you can easily see that shadows will make the color of the wall appear to be different shades. Sunlight has a very different effect on colors than incandescent light or florescent lights. Digital cameras start with white (the absence of color) to measure the effect of light and adjust the metering (measurement and accuracy) of all the other colors. Of course, white in a poorly lit room may appear gray or even yellow to some digital cameras. So how can you get accurate color? 1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Heating & Cooling Logo
607 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
