Question about LG RH1999H DVD Recorder/HDD Recorder
DVD setup will not list Foxtel chs. and now no display TV
I have a new DVD recorder RH397D and it will not recognise Foxtel channels. The drop down list below does not have my recorder ...it is probably too new so I clicked on another model.
AND for some reason it will not now display on the TV screen...although it did to start with. I think it is a channel problem but don't know how to fix it.
The DVD window is flashing 'prog 1' but the manual does not explain.
Help!
SOURCE: Need to play region 1 DVD in region 2
Hi I got a Lg HDD/Dvd Recorder Model RH1999H. Ihave a problem copying Dvd from the hardrive. When I load a completly blank disc, the recorder will not intialize the disc. How do get this recorder to intialize the disc to video. When i got to set up mode, I select Disc Format option, i cannot get into the format mode, I tried to change it but it does not change the only thing I see on the disc format mode is PBC highlighted.
Please advise
AmarE-mail nikraj@telkomsa.net
Posted on Jul 25, 2008
SOURCE: LG RHT397H DVD Timer record problem
Sorry used wrong site have moved to LG DVD forum. Ta
Posted on Jan 18, 2009
SOURCE: recorded onto my lg rh397d/rh399d, want to copy to dvd
You need to read page 37 "Dubbing a title"
Select the title you want to record and select the Dubbing option.
Posted on Apr 20, 2009
SOURCE: dstv to dvd recorder connection
  1. Grab your A/V composite wires and insert them into the Audio/Video OUTPUTS on the back of the satellite receiver. These are color-coded connections--red to red, white to white and yellow to yellow. The red and white connections are your audio feeds and the yellow is for your video.
  2. Look on the backside of your DVD/VCR dual recorder. You will see similar connections. Connect the other end of the composite wires to the Audio/Video INPUTS on the DVD/VCR dual recorder.
  3. With a second set of A/V composite wires, connect one end to the DVD/VCR dual recorder's A/V OUTPUT and the other end to the television's A/V INPUT. Again, be sure to follow the color code. Also, if your television has more than one available input, be sure to know to which one you made the connections (A/V 1, A/V 2, etc.).
Posted on May 02, 2009
vortash
  • 431 Answers
SOURCE: LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
Posted on May 12, 2009
I can no longer use Timer Record on my LG RH397D
use free to air tv aerials app (google or iphone in store) on your phone or tablet, this will help you line the aerial up with the transponder, that app also tells you the signal strength you should receive. as from recording on timer from av that was never a thought when recorders were made only transfer signal only.
Jul 02, 2017 | Televison & Video
Hello, I have purchased an LG RH397D DVD Recorder in Brisbane Australia. Eveything works well except that I cannot receive channel 73 (mate) and 90 (Go). I can press guide and the recorder will tell me...
its simple ,HD stands for "high definition" and either your TV or DVD player cant do HD ,these channels will be only screened in HD ,this is why you cant watch them ,you will need to update one or both of them .THANKS for using FixYa
Feb 10, 2011 | LG Televison & Video
I have tried tuning in my dvd recorder in the reset menu, but after the scan process a message appears "Check aerial connection. Help, what am I doing wrong?
make sure aerial is in dvd recorder press functions move down to others press enter move down to setup and enter highlight tuning move right and down to auto setup reset and enter
tou will see a warning message move to yes and enter the dvd recorder will start tuning and a list of all the stations that been found will be displayed after that it will start to scan for analog stations( BEEN TURNED OFF) once finished
picture will be displayed
if no list was seen when tuning in digital stations then make sure dvd is digital
and to check aerial put direct in to didgtal tv and retune tv
Dec 16, 2009 | Panasonic DMR-ES10 DVD Recorder
Cannot playback dvd-r on lg rh397d after recording from hdd. message is 'cannot playback due to navigation error' please help
When you burn a DVD, it is ONLY playable in the RH397D.
Buggy menus - and no way to flash the firmware.
Terribly designed remote.
HDD never seems to spin down, no matter how long it sits.
Doesn't play XVid.
I was a bit disappointed with this product. It does do, what is listed on the box, and one can't be too disappointed with that.
Sep 29, 2009 | Televison & Video
I can't get the recorder to keep my guide.
There might be a TV Guide issue located in your area, since the transition to digital, TV Guide have been updating there broadcast frequency which is know been done by CBS. Have unit reset by holding down channel up and down button for 15 second on the unit itself until 12 flashes on display, then power on unit and setup TV Guide, then have unit off for 24 hours especially between 11pm to 6am for listing. If issue still exist contact Panasonic to have issue send to TV Guide.
Sep 28, 2009 | Panasonic DMR-E85H DVD Recorder
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
Unable to get digital channels through dvd player
The built in tuner in this model LG is a standard not a digital tuner.
Apr 05, 2009 | Televison & Video
No display
Press the DVD button on the Philips remote. Make sure the yellow part of the RCA cable is plugged into Output/CVBS/Out on the back of the Philips, and that it is plugged into a yellow input of your TV. Change your TV channel to Av1, av2, video 1, video 2, aux, aux 2, or whatever the correct video channel is on your TV. Then press setup - you will get your picture.
In order for the coax connection to work on Ch. 3 of your TV, you will have to get an additional piece of equipment - an RF modulator. It's better just to stick with the RCA red, yellow, white cables.
Sep 02, 2007 | Philips DVDR3455H/37B
LG RH1999H DVD Recorder/HDD Recorder Logo
22 people viewed this question
Computer Repairing
Computer Repairing
