Question about Whirlpool LER4634J Electric Dryer
Need part number for dryer belt model ler4634eq2
  • 304 Answers
Part Number is Whirlpool part# 341241
Posted on Oct 03, 2009
What is wrong with a whirlpool 4 cycles 3 temperature dryer that will not get hot?
First clean the vents inside the dryer and to the outside be sure and clean around the blower wheel. Check the thermal fuse, the cutout fuse & all the thermostats. Check the heating element also check that it is not grounded to the heater box. Last check the centrifical switch on the motor as the heater runs through it.
Hope this will help you
Feb 27, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer model ler4634eq2 runs, but will not heat
Hello
No heat in your whirlpool is caused when the thermal fuse goes bad and needs replacement. As everything else is working so the problem is with the fuse which is located on the blower wheel housing inside the back panel and to replace you'll have to open it. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Whirlpool Dryers
Dryer will not start whirlpool model #LER4634EQ2 SERIAL #MK0296464 TYPE#D433-ELE-2406028-FM54
It might be the fuse.3727d80.jpg Be sure you do a bit of cleaning before you replace the fuse or it might just blow again.a611954.jpgca0922b.jpg Look for lint. I looked up your model. I once did a write up about what goes wrong, how to get into the machine, a training manual and videos. HERE
Bonus stuff
Helpful? Rate please.
Sep 19, 2010 | Whirlpool Dryers
I have this model dryer ler4634eq2, all you can here when you try to start it is the timer, I have checked and jumped both the thermal switch and the door switch, I have also tested my start switch for...
Check to make sure the belt is not broken. This may have the belt switch located behind the motor and if belt breaks this will also have same results since every thing else has been checked. Hope this helps.
Mar 02, 2010 | Whirlpool LER4634J Electric Dryer
Dryer was running. Put in a new load and it won't turn on now. I checked the fuse box, it was good. any idea. model # LER4634EQ2
Thermal fuse. Pull rear panel off and theres a little white fuse with two blue wires on it. Its got one quarter inch screw. You can tie the two wires together and check if that is your problem - but I recommend replacing the fuse. Good luck...
Nov 16, 2009 | Whirlpool LER4634J Electric Dryer
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Whirlpool Dryer LER4634EQ2
you can remove the back panel everything is acessed from ther, with a meter you can check for continuity of all the thermoats and heater assy, first one to check is the thermal overload fuse locate d in the middle of unit "white " usually blows when excessive temp is detected( blocked vent)
Mar 07, 2009 | Whirlpool LER4634J Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
142 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
