Question about Cameras
Wont turn on. when i press on button it makes noises like its trying to open then does nothing. battery is fully charged but could it be that? something happened to it when i first came to canada so i sent it home to get fixed under warranty and it worked again when i got it back for another 500 or so photo's. now it's not working again. and i havent been able to get any photo's for the last few months :( :(
SOURCE: When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Posted on Mar 23, 2009
mannforever
  • 23 Answers
SOURCE: Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Posted on Aug 11, 2009
  • 6 Answers
SOURCE: Kodak Easyshare M340 is fully charged but turns off immediately
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Posted on Sep 28, 2009
SOURCE: My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Posted on Jun 06, 2010
  • 11967 Answers
SOURCE: When I turn the camera on, the lens extends, makes
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 21, 2011
MY IPHONE DIED AND NOW WONT TURN BACK ON
First check to make sure your charger is working, plug it up to the computer and see if the battery charging display comes up.
Second I would check to make sure the battery is actually charging.
Third try a cold boot, hold the power and home keys down while it boots it could just simply be locked up.
Jan 09, 2013 | Apple iPhone4 4G iPhone 4
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
May 20, 2012 | Samsung DualView TL205 Digital Camera
I was playing a game and all of a sudden the screen went white and wont do anything,not even make a noise.how can i fix it?
Try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod from within itunes.
Apr 07, 2010 | Apple iPod touch
The lens is stuck open and nothing will work. Every time I try to turn it on or push a button it beeps and turns off.
First, make sure you have a charged battery. Once you have that, try turning it on, and gently press on the lens to try to help it reseat. You might try googling the problem, there are free suggestions to try before you take it to a repair facility. But if you do decide to have a shop fix it, get an estimate first. Oftentimes, the repair is about what you will pay for a good, used camera on Ebay.
Feb 22, 2010 | Samsung Digimax D53 Digital Camera
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
Honda Civic Dead Battery then won't start- Kill switch?
You must fully charge the battery again , injection models are a pain
Jan 12, 2009 | 2004 Honda Civic
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
Nokia 7373 wont turn on
This might work:
Switch off.
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Mar 15, 2008 | Nokia 7373 Cellular Phone
Casio EX-Z55 wont turn on after lens error
A lens error is something that can only be fixed my sending in to the repairs department. There is nothing that can be done at home to fix that.
Nov 29, 2007 | Casio Exilim EX-Z55 Digital Camera
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
