Question about Maytag MGDB400VQ Dryer
MGDB400VQ gas dryer will not heat? Does not dry
MGDB400VQ gas dryer will not heat? Does not dry clothes? Any suggestions?
    President:
  • Maytag Master
  • 1,922 Answers
Check for 1 leg of 240 volts input power missing,if you have power then either the hi-limit switch,thermal fuse,or the heating element is open
Posted on Oct 03, 2009
The clothes take 4 times the normal drying time to dry. Can you suggest anything, yhank you
If you are getting some heat periodically it is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you are getting no heat at all try this link Troubleshooting a gas dryer
Mar 21, 2011 | Whirlpool LGB6300 Gas Dryer
I dont know if this is the exact dryer I have or not but in general i have a couple of questions that need answered. 1) My dryer is no longer getting hot and drying my clothes 2) my timer never turns off...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | Kenmore 62802 Electric Dryer
The dryer doesn't heat up and dry the clothes. I checked the troubleshooting section and then cleaned the lint filter, which we do after every time we take dry clothes out, and then I made sure the exhaust...
heatman101
Sep 28, 2010 | Bosch Nexxt 500 Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Installed new gas Maytag Bravo yesterday. It will
is the gas on
sometimes these units get dropped if they fall hard you could have cracked the ignitor
Oct 03, 2009 | Maytag MGDB400VQ Dryer
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Maytag Neptune gas dryer sense dry time at 99, little or no heat
If this is a gas dryer, I'd suggest an inspection by the gas company or qualified technician. If the jets aren't firing correctly, you are wasting gas and possibly creating a hazard.
Mar 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MGDB400VQ Dryer Logo
148 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
