Question about Xerox Phaser 7760/YDX Laser Printer
Hello i hope someone can help me with my problem i need reset the fuser uit xerox phaser 7760,because the rollers both(up,low) are like new condition thank you
    Problem Solver:
You can get more life out of the fuser by removing one end and placing a piece of tin foil OVER the THREE FUSES, which are designed to blow at set times. Just tape it in place with some tape.
Good Luck
Posted on Jan 28, 2010
  • 7760 Jun 13, 2011
    Can you show me this process
    Guru:
  • 110 Answers
Sorry to tell you this but Xerox has develope a way where you can't reset your fuser from the main menu or the Diagnostic menu.After couple thousand pages the fuser is unusable. There is a company in Virginia where I get refurb parts www.iteminconline.com so what you can do is call them up to see if they can reset your fuser. So you don't have to pay like $300 for a fuser maintance kit . Good luck. 1-800-367-4836
Posted on Nov 05, 2009
How to reset the fuser xerox 7760
NVM setting
  • 744-354 (Fuser Warning Point). Set it to 490.
  • 744-355 (Fuser Life Point). Set it to 500
Sep 15, 2014 | Xerox Phaser 7760/GX Laser Printer
Reset fuser on Xerox phaser 7760
You don't need to reset it it. It should automatically reset with no problem you can try to clear the NVRAM . Careful because you will lose all the information you have stored in it like any IP address or specific settings. What it will do is bring the printer to"factory default settings. You can do it in "service diagnostic mode. goodluck
Feb 19, 2014 | Xerox Corporation 7760/Dn - Xerox Phaser...
Xerox 7760 paper jam
at which position it will jam it matters tell in detail or send a sanp of it
Apr 10, 2013 | Xerox Phaser 7760/YDX Laser Printer
Fuser upper failure is the message i am getting on my xerox phaser 7300. can anyone help please
Hello, The fuser or fuser roller is what actually bonds or melt the toner on to your paper. There is probably some type of temperature sensor, that senses the temperature of the fuser. If its not hot enough or just plain dead, it will give out an alarm similar to what your getting. You probably need to replace the fuser unit. You have a lower fuser and an upper fuser. You might be able to get away with just replacing the upper roller. The roller has a heating element inside and that's what probably defective.
Hope this Helps
Thank You for your feedback
Jan 31, 2011 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Phaser 7760 dirty printing
Dear User,
This is a common problem of all laser printers, don't worry i will give you solutions for this. If you can able to remove the DRUM set from the printer and check that any power leak or not, IF yes clean it well and insert into printer again take a printout , afterthat also coming like dirty. So please change the drum and put a NEW DRUM. Your drum capacity is crosed beyond the limit.
I hope that my suggession will helpful to you, if yes please rate this ...
Feb 27, 2010 | Xerox Phaser 7760/GX Laser Printer
I am looking for parts list for a XEROX Phaser 7760 we got a service manual but no parts list need to find feed rollers and one way bearings for # 4 &5 trays ASAP any one able to help
600K78460 Roll Kit (3 Rolls/Kit) but they are the same as a 7750
the bearings don't have no number on the 7760 service manuel.
but you can check this manuel for the 7750 they should be the same.
http://www.office.xerox.com/userdoc/P7750/7750_Web/partslist/index.html
Nov 05, 2009 | Xerox Phaser 7760DN Laser Printer
I have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
May 20, 2009 | Xerox Phaser 7760/YDX Laser Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 7760/YDX Laser Printer Logo
839 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
