Red rainbow in bottom left corner of my tv and the screen is blury
    New Friend:
  • 60 Answers
If you have a speaker or anything else magnetic near that corner move it away. It may take a few days for the built in degausing coil to de-magnetize it but it should go away it that's what caused it.
Posted on Dec 21, 2007
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
Sometimes I get a rainbow on the bottom of the screen.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Philips 60PP9202 60" Rear Projection...
Blury screen with rainbow image cannot read words on screen
The convergence integrated circuits have failed and most likely the 2 5A fuses have opened as well. I would find a local Mitsubishi service shop.
Sep 28, 2008 | Mitsubishi WS-65908 TV
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Blue line trouble
Hi Kracka,
Are you able to post a picture of the problem?
It sounds from your description that it might be a 'convergence' problem which is when the red, green and blue parts of the image aren't alligned properly.
Check in your menu to see if there is a convergence setting.
Hope this helps
Jun 26, 2008 | Panasonic PT-51G41 51 in. Rear Projection...
Apex GT2015 20 inch television
TVs Power Supply Unit may be faulty and you will have to get it fixed.
Opening up the TV may void the warranty.
Its better talk to TV Manufacturer's Tech Support.
Jan 09, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Accidently locked tv
Sorry but you're going to have to be a bit more specific than that.. What kind of Tv is it, what model number, is it the original remote, do you have an otherwise good pic and sound, do functions (vol, ch, power) on the Tv work???
Dec 11, 2007 | RCA 20F514TD 20" TV
3d/rainbow affect
Sorry to tell ya Gemini, but there are no user serviceable parts inside a TV set unless your a technician as theres several safety issues of Hi Voltage involved as well as unsoldering and soldering. You Have a convergence problem or Pincussion issue with your set. No quick fix for this one. You need to call in a pro to assist you with this repair. Good Luck
Jul 15, 2006 | Samsung PCL6215R 62" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
