Question about RCA P46921 46" Rear Projection Television
Picture on TV showed as small lines at the top of the screen. Sound was fine but picture was bad. This happened while playing a video game. Unplugged TV from the outlet for about a half hour. Plugged it back in and it looked ok. After about 7 hours and while watchng a DVD movie the lines came back again. Is something overheating or is the Video Input causing the problem?
  • 4,402 Answers
I would definitely say you have a heating up problem, im guessing either the convergance ic are heating up or HOT or horz output or a capacitor, you could try spraying freeze (radio shack carries it) when the problems starts showing up to isolate the problem.
Posted on Jan 02, 2008
Horizonal line across middle of screen top half of picture perfect bottom half has small lines in picture hitachi hd S 69 plasma
I'm not sure if this model is the one that has resistors that go bad. You can actually purchase a pack of resistors in a kit. It will come with solder, the resistors and instructions. You can lay the tv out and take the circuit board out to find the blown components, and replace the bad ones. Takes about an hour start to finish and will cost around $65.00. It has been a few years since I did this, so I'm not sure on the price.
Apr 04, 2015 | Hitachi UltraVision 55HDS69 55 in. Plasma...
My panasonic DMR-ES20 has sound but picture? have unpluged but still no picture???
maybe you unit is in progressive mode try to reset it by holding stop and play/x1.3 button at the same time for about 5 seconds.
Apr 22, 2014 | Televison & Video
My system works fine but some demo downloads won't play I have sound but the picture shows diagonal lines across the screen
Maybe the Demo Game isn't compatible with your TV, or your PS3. Try going to a friends house (who has a PS3 obviously), and try downloading that game on his. If it works, it could be just your PS3. If not, its probably the Game itself.
Jan 03, 2011 | Sony Playstation 3 (PS3) Console
2002 27" SONY Trinitron. Half-screen picture with bright line.
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
This is a common problem usually seen when playing copy protected tapes. The part of the picture affected is normally off the top of the screen. Sometimes the problem is also due to the VCR itself and differences in tapes. It's also possible for the TV itself to be causing this, although you would probably also notice this flag-waving (that's what it's called) on regular TV viewing if that were true.
Sometimes increasing the height of the picture can push the affected area off the top again. But this can also cause you to lose part of the picture you want. Also, the height adjustment may be difficult to find as it's not something normally used. On some TV's it's a small pot somewhere on the board, but most newer sets have electronic adjustments through a service menu that you need to know how to access.
I'd suggest trying another VCR first and play one of the tapes you know shows the trouble. That might be all it takes. Then consider trying to increase the picture height if it's just a small bit at the top of the screen.
Mar 12, 2009 | Zenith B25A11Z 25" TV
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here: which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
RCA P46921 46" Rear Projection Television Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
