I have a problem with my panasonic projector hd tv.I recently changed the (rear)light bulb on it and now when i turn it on it has no sound or picture. Also the light keeps blinking green every 2 seconds non stop.Can you please tell me what I can do to fix it?
  • 788 Answers
It is very possible that the Bulb that you have replaced is damaged.
If one of the filaments are damaged or shorted, it will not allow the system to power up.
Also, it is a good idea to change all projection tubes at the same time to balance the output.
My suggestion would be to have the tube you replaced checked and if faulty, replace it and the others.
I hope this has helped you.
Posted on Oct 03, 2009
WHY DOES MY HD OPTOMA DLP 70 TURN OFF AFTER FEW MINUTES?
If you have recently replaced the bulb you may need to reset the lamp counter in the projector menu.
If you have not replaced the bulb, the projector may be shutting down due to over-heating. Check that the projector is clear of as much dust and debris as possible.
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
Orange light came on replaced the bulb after a day it blew out then replaced bulb again blew out now the light is red please help
It sounds like it is not getting enough cooling. Clean the cooling paths. I am just taking a guess as I am not familiar with this unit.
Jun 16, 2014 | Toshiba 72HM195 72-Inch Diagonal...
My optavision hd 9500 projector's light doesnt come on, have changed bulb still won't work.
My optavision hd 9500 projector's light doesnt come on, have changed bulb still won't work. what do i do
Oct 28, 2012 | Office Equipment & Supplies
Hello, I have a LG rear projection tv model number LG 52SZ8R-ZA that has recently stopped working at 100%. The screen appears alot duller as though the brightness has been turned right down. Is the problem...
Hello, You can get better prices for bulbs on the Internet. I went through this problem with my set.
Sometimes there is an upgrade in bulb Wattage on an individual basis by Model. What you may be having problems with is a system called a "Light Engine". This assembly has the power module and a spinning part called a "Light Wheel".
Your problem then can be from any of these devices. Your old bulb could have a dark spot (As normal light bulbs can develop), a weak power module, or a light wheel not spinning at the correct RPM for clarity.
You can take a chance and try a new bulb yourself or call for a Technician to give you either a "Convergence Set-up" or Evaluation and Repair estimate.
I learned about the insides of these TV's from the Front-Projectors and my own Rear-Projectors which had Warranty Recalls. So I have seen Messed-up and know what it looks like and somewhat about the causes and cures.
If you are getting a Convergence service, you may want to get the Estimate, then install a new bulb through the Internet, and then get it all set up fresh with the new bulb.
Oct 11, 2011 | LG Televison & Video
I have a sony and it uses the KDF-E60.i turned the tv on then after like 5 min. the tv turned blank and the sound turned off and a while after the screen came back on and then the sound came back on.i ask...
so this is a projector , if the unit is turning off and giving led signal error like green flashing, your bulb needs a replacement. its a warning that it has nearly end of his lamp life. dust and poor ventilation can shorten the lamp life. its a good idea to clean the blower and ventilation inside the projector.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
I have a Panasonic 62 inch rear projector tv and the lamp light is turning red so my tv will not turn on, i was told its either the bulb or a dirty filter the question is where is the filter
It's most likely the Bulb. We had the same issue with ours only 1 year after buying it. Luckily we purchased from Costco and called them. They had someone come out, replace it and didn't cost me a dime. (When I called Panasonic they said the lamp was covered under the 5 year lap warranty, but the labor for someone to come out was going to be $100.)
Mar 13, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
It appears that your light engine is broken, I have the same problem. Have you recently changed the bulb with a non-panasonic part bought on the internet. I did this and think thats what caused the problem. I believe the new bulb burn at a higher temp thus causing damage to the Light engine filters
Jan 04, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
TV will not turn back on
had the same problem, I am pretty sure it's the projector bulb is burned out. easy to replace yourself
Jun 04, 2008 | Panasonic PT-53X54 53" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
