Question about Logitech Cordless Desktop EX110
The set is connected by USB to the laptop but I can't get it to work. Reset buttons, new batteries, checked usb plug, blown clean,nno dust, light on the receiver is on, lights flicker when the reset button is pushed, control panel properties for mouse and keyboard says the device is working... what did I do wrong???
  • 329 Answers
It seems that there is connectivity problem.. as your sensor is not receiving signal from keyboard or mouse.....you have to make connectivity by pressing button on sensor then press button on keyboard....similarly press sensor button on sensor then press button on mouse.....try this and do reply me
Posted on Oct 03, 2009
EeeTop all in one PC wireless keyboard and wireless mouse not working - bayyeries fresh and reset button already checked out
you must keep the batteries out for a few minutes and unplugged then re plug to a new usb port. hit the connect/ reset button on reciever alone with batteries still out of remote then put the new batteries in (lights come on remote you know you have good batteries) and then hit connect on that. that should work if not you must hit connect at the exact same time. thats how i fixed mine.
Mar 12, 2011 | ASUS Eee Top ET2002 20-Inch All-in-One...
Wireless Logitech mouse with NO connect button on it. Only buttons on it are Power and Reset (and one to open battery case). Cannot figure out how to connect to receiver. Was previously connected, but I...
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Mar 18, 2010 | Logitech Cordless Mouse
Mouse stopped working all of a sudden; replaced batteries and restarted computer. Light on mouse still not on after pusing the connect button
Your computer also has a connect button. If it is a USB optical mouse, you must push the connect button on the receiver that is plugged into the USB port as well as the mouse (and keyboard if it's all a set) If the mouse receiver is in the PC, like some Sony's...look around for the real tiny reset button..it's there somewhere.
Jan 13, 2010 | Computers & Internet
New batteries, power light on, no activity from mouse at all. Batteries went dead, installed new batteries now nothing works. Power light is on.
try holding down the reset button for 5 seconds. usually that will re-establish the connection to the USB dongle
Nov 24, 2009 | Logitech Cordless Mouse
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse doesn't work
LOOK FOR A BUTTON TO RESET THE MOUSE AND THE USB CONNECT SHOULD ALSO HAVE A RESET SWITCH ON THE USB CONNECT YOU NEED TO PUSH BOTH AT THE SAME IME SO THE CAN GET INSINK OR THE CHANNEL TO SET. SOME TIMES THE MOUSE HAS TO BE TAKEN APART AND CLEANED JUST LIKE THE OLD MOUSE BALL ONE, AND RESET THE MOUSE SETTING IN CONTROL PANAL, UPDATE DRIVE MAY ALSO HELP IF THERE IS ANY NEW FIXS
ROD
PS SOME TIMES THE LEAD TO THE BATTARY CONNECTION NEED THE THE SPRING PULLED OUT A LITTLE OR THE OTHER END WITH METAL TAB ON IT NEEDS PULLED OUT BECAUSE THE PLAY IN THE BATTERY COMPARTMENT IS LOOSE AND THE CONNECTION IS INTERMITTING A VOLTAGE CHANGE AND CAUSES THE MOUSE TO LOOSE ITS SIGNAL TO THE TRANSMITTER OR SET FREQANCES.
ROD
Feb 09, 2009 | HP Wireless Optical Mouse
The keys on my Logitech wireless keyboard have stopped working. New batteries installed. Shortcut keys to email, Internet home page, and calculator are working.
Did you press the connect button located underneath your keyboard and still didn't work?
  • It might need some cleaning?
  • Also check if is a key that has been stucked. Sometimes, removing keys and putting them back on will solve the problem.
  • See if the USB bluetooth is connected properly.
  • Check under the Device Manager. You might also need the Logitech updated driver???
Think for the possibilities. Let us know if one of the solutions worked for you.
Nov 10, 2008 | Computers & Internet
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Mar 02, 2008 | Sakar 62150 Keyboard
Keyboard/touchpad problem.
The keyboard and touch-pad are connected to an internal USB interface, If no USB interfaces are working at all this suggests that the USB host controller (a physical computer chip) has failed.
You can try a chip-set reset; disconnect both power and battery and hold down the power button for 30 seconds (timed), this will reset all chip settings to default and discharge any static buildup but this is in no way guaranteed to fix the problem. If the laptop is still under warranty arrange for repair.
In the mean time most of the Aspire 5100 series have a PC card slot on the side so you could use a USB or PS2 host card to connect a keyboard and mouse.
Dec 07, 2007 | Acer Aspire 5100 Notebook
Logitech Cordless Desktop EX110 Logo
151 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
