Question about Home Security
Some keys of FA 260 are stiff and hard to press. It is difficult to enter some of the numbers.
  • 75 Answers
I assume that its a keypad?, try something like rp7 or something that won't leave a gummy residue when it drys, get a hold of cotton buds or similar and clean around the edges of the pads if possible. It'll be crud buildup over a period of time most likely.
Posted on Oct 03, 2009
I enter a negative number and press M+ and get E
Did you enter a negative number using the "+/-" key and not an expression using the "-" key?
Feb 11, 2013 | Casio FX-260 Calculator
How to find log on a calculator
Since I do not know what Kenko calculator you have I will remain general.
Locate a key marked log (for common decimal logarithm)
Try the two options. One of them is bound to work
  1. Enter a positive number and press the key marked LOG.
  2. If that does not work, press the LOG key and then enter a positive number. If the calculator displayed log( , with a left parenthesis, insert a right parenthesis before pressing the = key.
To calculate the natural logarithms (LN), look for a key marked with LN and proceed as for the common logarithm. I am sure that the syntax (key sequence) that works for the common log will work for th natural log.
If no key is marked on top of it with LOG or LN, it may be because those markings are ON the body of calculator. In that case the functions are accessed by pressing a key marked SHIFT or 2ND, or 2ndF before the function LOG or LN.
Jun 25, 2010 | Casio FX-260 Calculator
Want to know how to calculate a number raised to a power
Use the general power key marked with X to the y ( look for the image of a key on same line as Power in the screen capture)
You enter a number then press the power key and finally the exponent. If exponent is complicated (fraction, negative or other) enclose the exponent in parentheses.
You aslo have dedicated keys for certain powers and roots (square, square rooot, cube, cubic root)
Jun 09, 2010 | Casio FX-260 Calculator
How do you input -log ?
Use the log function (common logarithm). See screen capture for markings on key.
To evaluate the negative of a logarithm
Enter the number (argument) of the logarithm
Press the = key to have it calculated.
While result is still displayed, press the sign change key or (+/-).
Beware that -log(number) is not necessarily a negative value.
Another way to calculate -log is to use the relation
log(1/a)=-log(a) .
Jun 01, 2010 | Casio FX-260 Calculator
Negative log
log(1/a)=-log(a) .
Your example
3 [EXP] [(] [+/-] 2 [) ] [LOG][=] [+/-]
[EXP] is the key to enter exponent of a power of 10 :It is a shortcut, so no 10 is entered. Respect the key sequence above.
[ (] left parenthesis to prevent ambiguity due to the negaticve exponent. Just a security.
[)] is the enclosing right parenthesis
[+/-] is the Sign Change key
May 06, 2010 | Casio FX-260 Calculator
How to find standard deveation
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
After you finish entering the data
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual.
Dec 15, 2009 | Casio FX-260 Calculator
Is there a way to fix the casio fx 260 solar to display numbers in scientific notation Like 3 x 10(raised to the 2nd power)?
This can be done by setting the calculator to the right MODE. Press MODE 9 to turn on scientific notation. For example, compute 1 / 200 = and you will see 5 with a -03 exponent in the upper right. Press MODE 9 again and it will be displayed .005
To enter numbers in scientific notation use the EXP at the bottom. To enter .005, press 5 then EXP then +/- then 3. You will see it displayed. Then you can perform calculations with this entered number.
Oct 01, 2009 | Casio FX-260 Calculator
How to compute standard deviation given a set of numbers?
Jan 15, 2009 | Casio FX-260 Calculator
Code for Eurovox EX5000PVR in Ireland
do you realise your missinga couple of numbers from the second line?
Dec 31, 2008 | StarTech.com StarView SV211K 2-port KVM...
EUROVOX TX NO CODES AND HOW TO INPUT CODES
scanned channels and all i get is data bein updated
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Home Security Logo
51 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
