Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
22.5 kohler wont pull uphill.
Every thing runs good and cuts good just want pull uphill.
    Sergeant:
    Champion:
  • 257 Answers
Not a expert just trying to help,, here is one thing to check,, check your drive belt to see if it is worn if so it maybe slipping,,hope this help
Posted on Oct 04, 2009
My tractor with 27hp Kohler engine runs fine without engaging the mower deck. Once engaged and I start cutting grass or go uphill, the engine starts to slow down. Also, it smells like exhaust fumes.
Try blowing the air filter out with compressed air. Or replace the filter. Make sure the choke butterfly in the carb is fully open, adjust the choke cable for correct function.
Jun 13, 2017 | Garden
When I am cutting the grass, when I try to go uphill the machine stalls . I am able to start it up again but a few minutes later the same thing happens.
Check the oil level...some engines have a low oil shutdown float inside the crankcase ..going up hill for an extended period of time allows the oil to flow to the side of the crankcase activating the float and tricking it to think the oil is dangerously low and shut it down...if it does it should have a small wire on the side of the crankcase..try operating on hill for shorter times..and make sure your crankcase is full...good luck..
Aug 01, 2015 | Simplicity 42 Toro Timecutter 20hp Kohler...
Kohler twin 22 wont start put carb cleaner in carb runs then shuts off
your actions indicate a lack of fuel in the carby or blocked jets. check filter in the tank, water in the carby , blocked fuel hose to carby, blocked inlet into the carby, blocked needle and seat
May 12, 2015 | Kohler Measuring Tools & Sensors
Huqvarna gth2548 won't go uphill
the trans on that mower is not strong enough to pull loads like that you most likely damaged the transmission but see if the belt is not slipping
Jul 31, 2012 | Garden
I have a husqvarna 22 horse kohler 48 inch deck, the mower runs fine but when u first put it in gear it is very slow to move more so in reverse. and sometimes does not want to go up inclines, can this be...
generally signs of a failing transmission. yes you can replace it yourself in less than a day with the proper tools. get the whole thing up on jacks, drop the deck, remove the wheels, remove linkage and belt, remove bolts and the thing falls into your hands. problem is that you can buy a used mower for less than the price of a transmission. look around for a used or possibly rebuilt exchange transmission. google helps a lot.
Oct 17, 2010 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
I have the same ,Sears Kohler tractor won't pull uphill
Have you checked the fluid level in the hydro trans, there is a drive belt from the engine to the hydro trans check and make sure that this is not worn or loose. Make sure that when you check the tension of this belt that you do not have the engine running or the parking brake set, since tension will be released from the belt when parking brake is applied. good Luck
Oct 07, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine runs -blade engages and throws grass, won't drive
craftsman 46in kohler22.5hp motor runs great ,cuts great, but wont pull uphill.
Sep 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cuts out when set to go uphill
could be a couple of things, I have found that alot of the time it is the belt or deck wearing out and the added effort of uphill causes overcurrent and trips the circuit to protect it from damage. Run your hand between the belt and deck and feel how smooth it is.
Jul 11, 2009 | Sportsart 6200 Treadmill
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
325 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
