Question about HP Compaq nw8440 Notebook
I can not start my laptop.
Even I press and hold the power button,the screen is still black.It worked before, I unplugded from the power source and I've used it on batterries.Now I switched again to power source and still the screen is black and no light is on.
  • lucilica Dec 21, 2007
    It doesn't power up at all neither on battery or AC adapter.
    I'm using an adapter which powers up other laptop(different brand)
    Thanks
  • 520 Answers
If the adapter works on other model adapters fine.
when you try to power up does the comp beep a few times.
first off disconnect power and remove battery,reconnect battery and adapter and try to power up.
could be build up off dust (bad connection with power button)
just press it hard and try to wriggle it about .all pc 's especially laptops are dust collecters.on the the outside they may look mint but on the inside you got a mini sahara going on
Posted on Jan 10, 2008
    Novelist:
  • 188 Answers
Try removing the battery and try it just on AC.
What happens exactly? Does it turn on but nothing happens or is it not even powering up at all?
If it doesnt power up at all then try another AC adapter.
Posted on Dec 21, 2007
I forgot my password and not even working with password hint and there is no other option where i can click except restart,shutdown and password field?
turn off your laptop by pressing and holding the power button. then wait a few minutes and start it up again. a black screen will come on and use the arrow keys to scroll down to safe mode
Mar 10, 2012 | Toshiba Satellite E205-S1904 Laptop
Screen stays black, despite computer is on antivirus program is working
The screen might be in sleep or hibernation mode, try move the mouse, and check if it will respond. If not forcely turned OFF the laptop, remove the power sources ( charger and battery) and hold down the power button for 10 secs. Put the power sources back and turn ON the laptop.
Hope it works :)
Mar 11, 2011 | Toshiba Computers & Internet
Acer Laptop Black Screen
Just to be clear this is not a fix for screen problems, this is a fix for a problem that prevents the laptop from booting at all. The laptop would not even attempt a POST and so would not even get as far as trying to output anything to the display.
I'm no expert but just wanted to share a fix that worked for me. For me it was a problem with the laptop not coming out of hibernation properly and completely freezing, the only option was to power off. On reboot nothing would happen, the screen would not even be initialised so it is nothing to do with the screen.
I can only theorise what the problem may be. As the solution is to remove the power lead, remove the battery and hold down the power button it would seem to be an issue with the laptop retaining some residual charge which is preventing the laptop from booting. I've heard of other poeple who have managed to fix this by simply letting the battery run out and then leave it overnight, this will again dissipate any residual charge but is just a much slower way of doing it. Holding the power button down with no power sources attached will dissipate this charge and allow the laptop to boot when a power source is reattached.
Unfortunately if the laptop boots and the screen is blank then it is a different issue, if the image on the screen is faint it is most likely a problem with the backlight and in these instances this fix will not work. Before posting this I thought this was an isolated incident but there have been so many replies it would appear to be a more common issue than I thought and works on many different models, not just the DV6599 that I've tried it on
Jun 01, 2010 | Acer Aspire 1642ZWLMi Notebook
It doesn't power..even when plugged or when it isn't plugged...it was left for 2 weeks..then came back from a lil' hols it refuses to power..
remove battery let sit for five minutes and reinsert the battery laptop must be unplugd from wall of coarse! good luck hope it helps!
Sep 01, 2009 | Acer Aspire 1640Z Notebook
SCREEN IS BLACK
i have this problem 2 days ago.. and this works on me... maybe on your's too
you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios
how to flash the bios:
STEP 1.download the AA1 BIOS from this link:
http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip
2. extract the file
3. rename the file 3309.fd to zg5ia32.fd
4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive
now, start the process
STEP 2
A. make sure the power cable is in
B. the laptop is turned OFF
C. Plug the usb stick in!
STEP 3:
Press and HOLD down the FN and ESC key together
then press the power button, while holding the buttons
release the power button and continue holding FN and ESC for about 5 seconds
release the buttons and the power light will start to blink
let the laptop run and DO NOT PRESS anything this can take upto 8 mins
when it's done the laptop will restart.
this works on me... good luck.. and i hope it will help you.....
Jun 15, 2009 | Acer Aspire One PC Notebook
Acer Aspire one screen stays black
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Black screen
press F8 key when u start your laptop thene nter in enable vgs mode.
Then go to dispaly propert then change resolution to 1024*768
Jun 13, 2009 | Acer Aspire One PC Notebook
Black screen on acer aspire one .tryed download the bios from acer on usb.it works but computer clicks on and off still black sreen.no lights at all just power lights.
TRY THIS AGAIN............ i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Jun 10, 2009 | Acer Aspire 5100 Notebook
Hp 4600 laptop
hmmm...try it with the battery removed only on AC power..
Feb 28, 2008 | HP Pavilion dv6000z Notebook
Keyboard & mouse are dead
I just fixed this problem by doing the following:
Hard power-off (hold the power button until the laptop turns off)
Unplug the AC adaptor
Remove the battery
Plug in the AC adaptor
Hold ctrl and turn the power on. You should arrive at a black screen.
Hard power-off again, then turn the power on.
Nov 11, 2007 | Acer Aspire 5100 Notebook
HP Compaq nw8440 Notebook Logo
121 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
