Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Cracked border to bottom shelf of frigidare refrigerator
We have used this refrigerator for a little less than a year.
The glass shelf on the bottom above the crisper the plastic that surrounds the edges of the glass shelf has cracked making the track of the Crisper not in tact.. Need to replace that bottom shelf and plastic border, I suspect they come intact..
  • 71 Answers
240350614 is the part number for the shelf border that you need...price is around $26
Posted on Oct 03, 2009
  • 15 Answers
SOURCE: water on bottom shelf of FRT15B3AW3
is the fan still running in the freezer compartment???? it may be your defrost thermostat.....
Posted on Aug 18, 2008
  • 178 Answers
SOURCE: i need new parts for
www.partstoday.com they will need the model number to be able tro search for the parts, enjoy.
Posted on Apr 06, 2008
Sea Breeze
  • 4655 Answers
SOURCE: whirpool et21pkxgw03 refrigerator
This is a common problem when the defrost condensate drain becomes blocked. Depending on the location of the blockage is the clue to how to prevent the blockage. Most times the blockage begins inside the freezer and overflows into the freezer creating a huge area of ice while at other times the blockage is just as it leaves the freezer and makes its turns going down to the pan below your refrigerator to reevaporate into the air inside your home. On the link below the whole page shows way of this happening and ways to stop it and resolve the problem. Read the entire page and use the part that most refers to you leaking problem. If you have further questions please contact me at appliancepartsse@yahoo.com, Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 24, 2009
  • 1531 Answers
SOURCE: broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Posted on Feb 09, 2010
iwillfixforu
  • 619 Answers
SOURCE: puddles on top shelf and under crisper drawers
This is not a major repair and also a very common problem. You will need to turn unit off and remove everything from inside the freezer. After this remove the back panel of the freezer and you will see ice built up at the bottom of the coils. You will have to remove all this ice and clear the defrost drain trough and tube. After the ice is removed you will see the defrost drain located about midways. Use a hair dryer to melt this then take a cup of very very very hot water and pour a little in the tube. Let stand for 5 minutes then dry it up real good and repeat. Do this till the drain clears and water flows freely. Then reassemble and you are good to go.
Posted on May 28, 2010
Part Number for E522B glass shelf
if you measure the broken shelf or take it to your local glazier they will cut the proper glass to size for you and its not expensive
Mar 20, 2014 | Fisher and Paykel Active Smart E522B...
I have a frigidare 20.6 frig. approxiamately 10...11 yrs old im find water puddles on top glass shelf and bigger puddles at the bottom I cleaned as much as I could the fan is working help model...
Hello Donna, I am happy to assist you. I understand that water is collecting in your refrigerator. Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
I certainly hope this troubleshooting tip resolves your concern. If you have any additional questions, please feel free to respond.
Aug 03, 2013 | Frigidaire Refrigerators
My frigidare refrigerator has a freezer on top but the fridge door has dropped it is a newer frigidare how do I fix
The bottom hinge needs slackening off, lift the edge of the door in place and retighten the hinge screws; if it's not that loose, a sharp tap with the heel of your hand may bring it back into line
Apr 24, 2012 | Frigidaire Refrigerators
I have an LFRD25850SW Fridge. The bottom shelf above the crisper drawers has cracked at the left front and is causing the drawer to stick. I need to replace the shelf frame (glass is OK). Can you give a...
The shelf frame is cracked . It can be purchased if the part is still available from LG . I wouldn't hold out hope though because LG is notorious for discontinuing parts after 3 years. Find a parts supplier who has contact with LG parts to see if it's still available . I was able to order one for my customer back in the spring.
Oct 22, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Broken shelf? help!
Feb 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
Maytag refrigerators mtbe1956de liquids have dripped on to the bottom glass shelf and seeped under the edges where it cannot be cleaned. do I have to remove the vegetable drawers and totally dismantle the...
brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Jan 12, 2010 | Refrigerators
Liebherr fridge parts? The plastic on the glass shelf has cracked and I need to replace the shelf but I don't know where I can do this... I'm also not sure what model the Liebherr fridge is either...
There should be a tag with model # on it somewhere on unit. Usually in inside side wall of fridge section. Or maybe on back of unit. Definitely need model # to order part.
Sep 08, 2017 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
261 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
